bad part throttle
Old Dec 1, 2004 | 02:39 AM
NOSED_CRX_VTEC's Avatar
Default bad part throttle Why??
I would like to know if anybody could help me sort out a problem i'm having with
me 91 crx vtec with a b16a1 and a revhard stage 2 turbo kit.
I'm running the hondata S200 system in an obd1 ecu with dizzy and 4 wire O2 sensor with a jumper harness going to my obd0 harness and using the obd0 engine sensors but with dms 450cc injectors and the stock resistor box and 3 bar map sensor.
The problem i'm having is the engine will not respond the throttle when the
throttle drops below 6.5% and then will only respond again when the thottle
goes above 9% this is all at a steady speed and ONLY if the car has been
stopped and then started in a very short space of time e.g. when the engine
stalls and then restarted but if i turn the ignition off for a long space of
time the engine will not have the problem.
Thanks for your help.
Modified by NOSED_CRX_VTEC at 1:43 AM 12/2/2004
Old Dec 1, 2004 | 04:43 PM
Default Re: bad part throttle Why?? (NOSED_CRX_VTEC)
Any body??
Old Dec 2, 2004 | 10:41 AM
beepy's Avatar
Hitting fuel cut early? Are you using a WBO2 and if so is it going lean?
Old Dec 2, 2004 | 10:46 AM
t04ecvc's Avatar
I thought I read once that DSM 450's are not compatible wit hthe hondata system. I'll look around and see if I can find it.
Upon looking around, seems like plenty of people are not having probs with the dsm 450's.
Old Dec 2, 2004 | 10:51 AM
t04ecvc's Avatar
Default Re: (t04ecvc)
I would datalog the times it does it and let us know what you see. Most likely you just need a little fine tuning.
Old Dec 3, 2004 | 08:47 AM
I just checked the resistance of my 450 injectors and it's 3.1 ohms but honda say it should be 1.5 to 2.5 ohms, could this be the reason for my problem.
milanoteggy
Jul 13, 2012 10:10 PM
d16sandrail
Jul 7, 2009 09:59 AM
thiendegigolo
Jun 25, 2009 03:24 AM
bikeboy80
Oct 4, 2002 07:02 AM
