Cutting out when hitting v-tec/highspeed map?
Old Dec 3, 2004 | 07:34 AM
DOHCarp's Avatar
Default Cutting out when hitting v-tec/highspeed map?
Hey everybody, well I finally had a chance to start tunning my car after so many problems......head was bad, manifold problems, wireing issues, and no dyno time.
Right now I am running into a big problem!
I am running hondata s200b and every time the car switches over to the High speed map it litterally cuts out...the car basically shuts off. So wherever I set V-tec the car shuts off right now no matter what timing or fueling I give it, lean or rich it just does it.
Anyone have any suggestions?
Modified by DOHCarp at 5:01 PM 12/3/2004
Old Dec 3, 2004 | 10:35 AM
DOHCarp's Avatar
Default Re: Cutting out when hitting v-tec/highspeed map? (DOHCarp)
Anyone ever run into this problem?
Old Dec 3, 2004 | 12:23 PM
pissedoffsol's Avatar
25 Year Member
yeah- i had the same **** happen to me.
the "upper" blue and red lines are where it happened...
you can see it just shut off.
I forget where it is right now, but there was a check box that was enabled that did this. i sent a pm to my tuner but hes away right now... i'll be back
Old Dec 3, 2004 | 05:16 PM
DOHCarp's Avatar
Default Re: Cutting out when hitting v-tec/highspeed map? (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">
I forget where it is right now, but there was a check box that was enabled that did this. i sent a pm to my tuner but hes away right now... i'll be back</TD></TR></TABLE>
Any luck talking to your tuner?
Old Dec 4, 2004 | 07:17 AM
DOHCarp's Avatar
Anybody?
Old Dec 4, 2004 | 07:26 AM
hondaguyef's Avatar
Is it like a very violent break up or does the engine just turn off?
Phil
Old Dec 4, 2004 | 07:33 AM
DOHCarp's Avatar
Default Re: Cutting out when hitting v-tec/highspeed map? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Is it like a very violent break up or does the engine just turn off?
Phil</TD></TR></TABLE>
The engine just turns off. I checked boost cut and rev limits.
Old Dec 4, 2004 | 09:11 AM
25 Year Member
talked to my tuner, but he can't remember ether. sorry man
Old Dec 4, 2004 | 09:31 AM
DOHCarp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">talked to my tuner, but he can't remember ether. sorry man </TD></TR></TABLE>
Thanks for trying...its appreciated.
anyone...this is killing me!
Old Dec 4, 2004 | 09:33 AM
locash's Avatar
Post screenshots of your maps, or send me the file, I can figure it out for you..
-joe
Old Dec 6, 2004 | 12:02 PM
DOHCarp's Avatar
Default Re: Cutting out when hitting v-tec/highspeed map? (locash)
Anybody think of anyhting over the weekend for me?
Old Dec 6, 2004 | 12:28 PM
*Boostwerks*'s Avatar
what about Vtec Pressure, and Spool?
m/heg6
Jul 26, 2011 10:06 PM
Civicman86
Mar 11, 2007 06:36 PM
Jim Truett
Dec 3, 2006 05:17 AM
JFG Kevin
May 26, 2006 08:27 AM
abmerop18
Jan 19, 2005 07:08 AM
