Things to replace while rebuilding engine , gaskets and such >>
Old Nov 30, 2004 | 10:56 AM
platinum00's Avatar
Default Things to replace while rebuilding engine , gaskets and such >>
getting read to put my motor back togehter i just want to make sure im not missing anything.
im replacing these items not including my engine build up ..
let me know if they really need done or if im missing something
Engine:
headgasket
intake manifold gasket
exhaust manifold gasket
throttle body gasket
front and rear main seels ( is this needed, it was done 4k ago. )
water pump and gasket
oil pump and gasket ( is this need, only 40k on car )
oil pan gasket
Tranny: Installing a diff so replacing these
speedo gear
diff bearing, both of them
isb bearing
isb seal
thrust washers.
thanks for the input.
platinum.
Old Nov 30, 2004 | 11:01 AM
Go Fast Civic's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (platinum00)
for the engine just replace the head,intake, and exhaust gaskets. no reason to replace the TB unless you had it off, same way with tthe oil pan gasket. but i would replace the water pump and gasket since they are cheap and like to go to hell all the time.
Not sure about any of the tranny things as i never installed a Lsd before, but dont forget about a throw out bearing and getting yout fly wheel turned. that always helps imo.
Old Nov 30, 2004 | 11:05 AM
platinum00's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (sportinemotions)
good info about the flywheel, it's only has 4k on it, but im sure it wont hurt.
what about the oil pump. what are the life on these bad boys. should i risk it, or are they pretty stable.
platinum.
Old Nov 30, 2004 | 11:07 AM
Phil Koury's Avatar
Putting a used oil pump into a new motor build isn't the best of idea's. It's very rare but i've seen them fail.
Old Nov 30, 2004 | 11:09 AM
VTC_CiViC's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (pkoury)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkoury &raquo;</TD></TR><TR><TD CLASS="quote">Putting a used oil pump into a new motor build isn't the best of idea's. It's very rare but i've seen them fail.</TD></TR></TABLE>
PM civicflnum1 and ask him about oil pump failure
.. I shoulda taken a picture of that thing!
Old Nov 30, 2004 | 11:16 AM
dennis's Avatar
don't forget oil pickup gasket
I reused my exhaust gasket fine. I also heard that you can reuse your IM gasket if you put wd40 on it so it doesn't stick. I don't know. I'll find out.
Not sure if your motor has such a thing, but on my f22b2, I replaced my oil restrictor and seal.
For parts, I've been real happy with Majestic Honda - http://www.hondaautomotiveparts.com/home.htm
Old Nov 30, 2004 | 11:30 AM
RyanEJ8's Avatar
I reused my oil pump in my engine build. It had about 45,000 miles on it at the time.
Old Nov 30, 2004 | 11:32 AM
platinum00's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I reused my oil pump in my engine build. It had about 45,000 miles on it at the time.</TD></TR></TABLE>
how many miles do you have on your car now. have you had any issue's, stock gear im assuming
platinum.
Old Nov 30, 2004 | 11:33 AM
platinum00's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">don't forget oil pickup gasket </TD></TR></TABLE>
i knew there would be something.
thank you
platinum.
Old Nov 30, 2004 | 11:35 AM
adictionbass's Avatar
should that be replaced if you just pop of the oil pick up for a min then bolt it back up?
Old Nov 30, 2004 | 11:41 AM
sporkcrx's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (adictionbass)
Mr. Gasket makes a gasket set for d16a6's in crx's, not sure about newer cars though.
Old Nov 30, 2004 | 11:51 AM
dennis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">should that be replaced if you just pop of the oil pick up for a min then bolt it back up?</TD></TR></TABLE>
I'm guilty of not replacing it, but they're dirt cheap. Just put an order together before hand and get all your goods. Don't forget to have some Hondabond on hand - as well as enough torque wrenches to cover all your torque ranges.
Old Dec 1, 2004 | 08:57 AM
platinum00's Avatar
anything else
platinum.
Old Dec 1, 2004 | 09:07 AM
PM-Performance's Avatar
oil pickup gasket? I never even used it once i scraped it off, Just hondabonded that ****** and worked great.
Oil pump and water pump isnt needed, but is a good idea. Just less headaches for later. Its easier to replace while its out of the car then doing them with the motor in. Just my .02
Old Dec 1, 2004 | 09:10 AM
platinum00's Avatar
Default Re: Things to replace while rebuilding engine , gaskets and such >> (itr206)
thanks.
how much is a oil pump, and im assuming oem is the way to go for a mild hp setup.
platinum.
Old Dec 1, 2004 | 09:11 AM
OEm for any kind of set up. There are guys running close to 1k hp on them.
Retail they are like $120-130 a piece i think ., I pay like $70 for them though. i got an acct at Honda
Old Dec 1, 2004 | 09:18 AM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I pay like $70 for them though. i got an acct at Honda </TD></TR></TABLE>
can you hook it up.
platinum.
Old Dec 1, 2004 | 09:39 AM
eddyboy's Avatar
Pickup a bottom end Gasket kit from honda.
They come with all the needed gaskets to do the bottom end.
They generally run abou 50-60.
The expensive one is the Top end gasket kit which generally runs around 200. But man it comes with every single gasket you can think off. Injector seals, Thermostat gasket, Head gasket, TB gasket, Valve seals, even the seals which go around the spark plug holes on your valve cover.
But they run around 200 from honda.
Great idea if your building your head as well.
If your rebuilding your tranny you should also replace the your axle seals. I highly suggest you pickup a seal driver, it will make your life a whole lot easier. Trust me as I just reacently rebuilt my motor, head, and tranny.
Also a good time to pickup a Hondata IM gasket. Lower intake charges and is reusable. Since I am going turbo I had the oil pan tapped and welded. I just used a CAP from Home Depot. Same thing with the Oil Feed. I installed my sandwhich adapter and feed line too. So when I finish the turbo setup it all just a bolt in affair.
GL
Old Dec 1, 2004 | 10:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">
can you hook it up.
platinum.</TD></TR></TABLE>
lol. No. I can sell it to you cheaper than Honda will, but you wont get it form me at my price. Gotta pay for my lifestyle somehow.
Old Dec 1, 2004 | 10:10 AM
platinum00's Avatar
hookers and booze is not a good lifestyle man.
pm me and hopefully we can work something out.
platinum.
Old Dec 1, 2004 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">hookers and booze is not a good lifestyle man.
Some like cars, some like tvs, some like women , some like jewelry, I just happen to like them all. lol.
Honestly your better off trying someone else on the site. I dont sell parts, dont have time really. Just making a general comment.
Old Dec 1, 2004 | 11:15 AM
turbosi03's Avatar
don't forget the O-ring on the oil pump... and also if your replacing eveything the helms tells you to then get the dowel pins that go under the head and on top of the head.
also the cam oil seals...
oh and there's two O-rings for the pipe that goes from the water pump to the thermostat housing... on my b16 anyway.
ezza
Nov 5, 2009 02:27 PM
GSR_hatch936
14
Oct 30, 2007 11:09 AM
wildoutwhitegsr
Feb 15, 2006 09:29 AM
Jonathan_ED3
Apr 11, 2003 09:02 PM
