can you trick a map sensor?
Old Dec 2, 2004 | 07:54 AM
Btothe3rdDegree's Avatar
Default can you trick a map sensor?
i know you can get a missing link or check valves, but can you just take the map sensor out and let it stay there? technically it would read 0 vac so i dont think it would throw a code...
Old Dec 2, 2004 | 07:58 AM
mattssi's Avatar
It would throw a code, because technically then the map sensor would not think your car was running. At idle your car sits at 15-20 vac, and transitions to 0 at wot, then if you have a turbo, when the turbo starts to spool, you will start to read boost. But having your map unplugged will do nothing but harm your engine. It would be best to get a system that will utilize your map sensor, not (trick) it.
Old Dec 2, 2004 | 08:02 AM
FOrSfEd's Avatar
Default Re: (mattssi)
good explanation above
Old Dec 2, 2004 | 08:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">It would throw a code, because technically then the map sensor would not think your car was running. At idle your car sits at 15-20 vac, and transitions to 0 at wot, then if you have a turbo, when the turbo starts to spool, you will start to read boost. But having your map unplugged will do nothing but harm your engine. It would be best to get a system that will utilize your map sensor, not (trick) it. </TD></TR></TABLE>
so a 3 bar?
Old Dec 2, 2004 | 08:11 AM
Johnyquest's Avatar
Default Re: can you trick a map sensor? (Btothe3rdDegree)
The MAP sensor is like... the #1 most important sensor in your motor. It and RPM are THE two things the ecu uses to fuel your motor... you can't just take it out...
Matt
Old Dec 2, 2004 | 08:26 AM
Default Re: can you trick a map sensor? (Johnyquest)
so is a 3 bar the only safe way to ad more boost? how much does a stock map sensor hold in psi?
Old Dec 2, 2004 | 08:40 AM
95hatch-NK's Avatar
yeah, how exactly does a 3 bar interact with a honda ecu? do they communicate enough to just use an FMU and a 3 bar and be all set? or does a 3 bar give off different voltages that the honda ECU's don't understand?
if they do work, what's the best 3 bar to get?
Old Dec 2, 2004 | 08:43 AM
raene's Avatar
This should help.
http://www.pgmfi.org/twiki/bin...ensor
Old Dec 2, 2004 | 08:55 AM
Aggressive Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">so is a 3 bar the only safe way to ad more boost? how much does a stock map sensor hold in psi?</TD></TR></TABLE>
From my knowledge a stock map sensor reads up to 11psi.but only if you areusing some kind of ecu such as hondata or aem,otherwise the computer goes limp.
If you have either of those ecu's get a 3bar,if not get both ecu and 3bar
Old Dec 2, 2004 | 09:06 AM
Default Re: can you trick a map sensor? (aggressivemotorsports)
yeah i run uber
Old Dec 2, 2004 | 09:09 AM
95hatch-NK's Avatar
so - if one is to run a 8psi wastegate and uberdata, a stock MAP will work great?
i'm sorry for stealing the post...
Old Dec 2, 2004 | 11:32 AM
Default Re: can you trick a map sensor? (86hatchfire)
yep, that is what i am running right now
Old Dec 2, 2004 | 12:06 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86hatchfire &raquo;</TD></TR><TR><TD CLASS="quote">so - if one is to run a 8psi wastegate and uberdata, a stock MAP will work great?
i'm sorry for stealing the post... </TD></TR></TABLE>
Yep.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">yeah i run uber</TD></TR></TABLE>
Good. You NEED to get a 3 bar mapsensor if you expect to go over 11 PSI. The stock ones are 1.75 Bar (1.75BAR = ~11PSI). I got a GM 3 bar map sensor for $65 shipped by calling up Motec. Someone told me to just call them so i got there number at there website and I ordered one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86hatchfire &raquo;</TD></TR><TR><TD CLASS="quote">yeah, how exactly does a 3 bar interact with a honda ecu? do they communicate enough to just use an FMU and a 3 bar and be all set? or does a 3 bar give off different voltages that the honda ECU's don't understand?
if they do work, what's the best 3 bar to get?</TD></TR></TABLE>
You have to run a full standalone system (AEM EMS) or hondata/Uberdata to use a 3 bar map sensor. No if/ands/ or buts on that one. This is because your entire fuel maps and ignition maps won't work if your ECU still thinks you run the stock one. Yes the voltage is different, but you also have to tell the ECU that the voltage means different things.
Old Dec 2, 2004 | 12:27 PM
Frozen E's Avatar
H-T White Ops
Default Re: can you trick a map sensor? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Good. You NEED to get a 3 bar mapsensor if you expect to go over 11 PSI. The stock ones are 1.75 Bar (1.75BAR = ~11PSI). </TD></TR></TABLE>
Uhmmm, no. 1 BAR is 14.7 psi. So a 1.75 is actually about 25.7 psi or so.
Don't know if you can use your stocker up that high. Just wanted to correct that.
I think somewhere you have to factor in the -14.7 psi of vacuum (which is actually measured in "HG instead of PSI) that a stock MAP measures too. Not quite sure but I know it comes into play.
Old Dec 2, 2004 | 12:50 PM
blundar's Avatar
Default Re: can you trick a map sensor? (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.pgmfi.org/twiki/bin...ssure
education 0wns you.
Old Dec 2, 2004 | 01:01 PM
Frozen E's Avatar
H-T White Ops
Hmmmm. Had no idea that MAP sensors used absolute pressure.
Old Dec 2, 2004 | 01:04 PM
93turbo16's Avatar
I wonder what the A and P stand for in MAP... haha
Old Dec 2, 2004 | 01:08 PM
Frozen E's Avatar
H-T White Ops
Eh whatever.
Old Dec 2, 2004 | 01:52 PM
95hatch-NK's Avatar
Default Re: (IslandSi)
very informative thread, thanks everyone.
Old Dec 2, 2004 | 02:47 PM
JonnyCoupe's Avatar
Just to make you feel even more silly 1 bar is 14.5 psi
14.7 psi is typical atmospheric pressure of 101.3Kpa
Old Dec 2, 2004 | 04:57 PM
i-speed's Avatar
On my old set up, built d16z6, stock ecu, apex vafc & Itc, 600cc inj .I made 440whp 365 ft/lbs on a stock map sensor w/ 5 one way check valves, t3 60-1, 22 psi & 50 shot n2o (for spool up & to burn thru the fuel) .So i guess it just depends ghetto or not, you can fool a map sensor !
Old Dec 2, 2004 | 08:52 PM
adseguy's Avatar
Don't know if you can use your stocker up that high. Just wanted to correct that.</TD></TR></TABLE>
Yeah I factored in the 14.5 PSI of pressure that is on top of our heads because of that whole damn gravity thing! . So in other words you have 25.5-14.5 which about 11 PSI above atmospheric pressure to over in. Thank god honda put in a 1.75 BAR instead of just a 1BAR. I wonder why?
si_motor_spt
Sep 9, 2007 12:31 PM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
