Help w/ NOS nitrous setup
Old Dec 28, 2004 | 10:55 AM
EFRue57's Avatar
Default Help w/ NOS nitrous setup
I just bought this NOS nitrous setup from a friend and am putting it on my crx. However he is out of town so i can't ask him for help and somthing stumped me. does anyone know which vaccum line connects to this or if it is a vaccum line at all?
Modified by EFRue57 at 8:06 PM 12/28/2004
Old Dec 28, 2004 | 11:59 AM
MooreBoost's Avatar
Default Re: Help w/ NOS nitrous setup (EFRue57)
Should be to your FPR I think.
Old Dec 28, 2004 | 12:34 PM
ScrapinSi's Avatar
You tee it into the fuel pressure regulator. When you activate the n2o, it bumps the fuel pressure to dump more fuel to compensate for the n2o.
Old Dec 28, 2004 | 01:06 PM
PM-Performance's Avatar
Default Re: Help w/ NOS nitrous setup (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">You tee it into the fuel pressure regulator. When you activate the n2o, it bumps the fuel pressure to dump more fuel to compensate for the n2o. </TD></TR></TABLE>
Old Dec 28, 2004 | 01:14 PM
MooreBoost's Avatar
Default Re: Help w/ NOS nitrous setup (itr206)
Are you sure you tee into it? It seems that the extra pressure could just bleed back into the manifold.
EFRue57's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSI &raquo;</TD></TR><TR><TD CLASS="quote">You tee it into the fuel pressure regulator. When you activate the n2o, it bumps the fuel pressure to dump more fuel to compensate for the n2o.</TD></TR></TABLE>
thanks........now that i actually looked at all the parts, what you said just made sense. there was a T fitting that i also didn't know what was for and i now understand. thanks for the help.
Old Dec 28, 2004 | 01:39 PM
Default Re: Help w/ NOS nitrous setup (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you tee into it? It seems that the extra pressure could just bleed back into the manifold.</TD></TR></TABLE>
you have to T into it. its gotta get the same vac source as the FPR to raise the pressure when juice is induced
Old Dec 28, 2004 | 01:41 PM
dabig1's Avatar
what shot are you gonna run?what engine?Built?
Old Dec 28, 2004 | 04:14 PM
EFRue57's Avatar
Default Re: Help w/ NOS nitrous setup (dabig1)
a 60 shot on a stock ls motor
Old Dec 28, 2004 | 04:15 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">a 60 shot on a stock ls motor</TD></TR></TABLE>
I probably wouldn't go any higher.
Old Dec 28, 2004 | 07:09 PM
EFRue57's Avatar
i won't......
Old Sep 14, 2005 | 10:50 AM
b18_crx's Avatar
NAWZ!
RICE POLICE SIP
May 19, 2005 01:42 PM
SiR831
May 5, 2005 05:12 PM
sol2nr
Feb 16, 2004 07:00 PM
YourHondaSucks
Feb 8, 2004 03:30 AM
92SiB18C1
Apr 25, 2003 05:35 AM
