boost leak question
Old Dec 26, 2004 | 05:54 AM
8herout's Avatar
Default boost leak question
if you have a boost leak will your boost gauge still read the correct psi?
Old Dec 26, 2004 | 05:56 AM
b18bturbo's Avatar
Default Re: boost leak question (beat-her)
no if you have a boost leak your boost guage will read whatever psi where you have your tee hooked up forthe source. If it is leaking and not getting full boost then ofcourse it would be lower, but it would still read correctly.
Old Dec 26, 2004 | 06:04 AM
8herout's Avatar
Default Re: boost leak question (b18bturbo)
well what im saying is that my gauge is reading 7psi but it doesnt pull at all. it feels like its not even as fast as stock. maybe my turbo is blown. thanks for the reply
Old Dec 26, 2004 | 06:07 AM
b18bturbo's Avatar
if its getting 7psi whats your tune like. is your car serviced and no other issues that you can think of.
Old Dec 26, 2004 | 06:17 AM
8herout's Avatar
well i have cel and it the tps,map,knock sensor and right know im running a fmu i also got hodata but wating for injectors to tune on a b17. it ran fine before i put the turbo in but know the vtec dont even work what can be wrong? thank again
Old Dec 26, 2004 | 08:54 AM
crispydee's Avatar
If you have a cel then the engine will be going into limp mode.
Old Dec 26, 2004 | 09:41 AM
primeredbeast's Avatar
Default Re: boost leak question (crispydee)
check motor compression or what does you vaccum read at idle??
Old Dec 26, 2004 | 10:14 AM
Street Ghost's Avatar
Default Re: boost leak question (primeredbeast)
Can you rev past 4k?
Old Dec 26, 2004 | 08:26 PM
8herout's Avatar
Default Re: boost leak question (_Edge.ONE)
my vacuums at 20 and yeah, i can rev past 4000 but how do know if your in limp mode?
Old Dec 26, 2004 | 08:28 PM
adseguy's Avatar
You can't rev past 3.5k (limp mode)
Old Dec 27, 2004 | 01:34 AM
crispydee's Avatar
Default Re: boost leak question (adseguy)
in my odb0 i can rev to 7000 but with very little power
Old Dec 27, 2004 | 07:02 AM
8herout's Avatar
well guy, it seems like some liquid is coming from the head where the exhaust ports are in to the manifold what can that mean
Old Dec 27, 2004 | 07:04 AM
b18bturbo's Avatar
what kinda of liquid is it coolant, moisture, oil what type of liquid.
if it is coolant or oil most likely the head gasket issues
Old Dec 27, 2004 | 07:07 AM
8herout's Avatar
i dont really know what is, its not oil kinda more like water. do you think my head gasket is blown and if it is will that make the car feel under power?
Old Dec 28, 2004 | 05:55 AM
8herout's Avatar
somebody help please
Old Dec 28, 2004 | 05:59 AM
b18bturbo's Avatar
run a compression test as well as leak down just to verify it yes the car will run crappy with low compression in given cylider if the gasket is blown
also what color are you plugs are they burning normal you can tell alot by a plug
Yoonit1
Oct 27, 2013 06:59 AM
nzrnk
Apr 5, 2005 04:40 AM
kabaroo
Jul 18, 2004 03:27 PM
genop
Mar 31, 2003 06:04 PM
fire7882
Oct 17, 2002 04:27 PM
