550 injectors and fuel pump
Old Dec 25, 2004 | 07:43 PM
b18-c-rx's Avatar
Default 550 injectors and fuel pump
i'm looking at 550 cc RC injectors for my ~280 hp b18c. my calculations show me that
a. this is the right injector size for 80% load and
b. i only need a 190 lph fuel pump, not 255.
my questions are:
1. is my 550 cc/min injector size too big
2. why does everyone use 255lph fuel pumps, it doesnt seem necessary for any of their applications
Old Dec 25, 2004 | 08:03 PM
93turbo16's Avatar
255LPH isn't necessary in most ocassions, but you never know where it will go. And 550s will be fine, just in case you want to build more power. But 450s or 440s would be ok too.
Old Dec 25, 2004 | 08:05 PM
b18-c-rx's Avatar
Default Re: (93turbo16)
is there an issue with getting too big of a fuel pump (bad idle, for example)?
also, i read somewhere (i think it was a. graham bell) that injectors work best when at .60 duty cycle in sequential applications, so the 550s may be better. if i tune it right, larger injectors shouldnt be a problem, correct?
also do I want the high resistance or low resistance injectors? =p
Old Dec 25, 2004 | 08:10 PM
93turbo16's Avatar
Exactly, you can't tune with fuel you don't have... So leaning them out is the best way to do it, except for possible idle problems, but it should be ok, definitley many people running 550cc+ injectors.
Old Dec 25, 2004 | 08:14 PM
b18-c-rx's Avatar
thats what i figured. so is there no issue whatsoever with the fuel pump?
Old Dec 25, 2004 | 08:16 PM
93turbo16's Avatar
shouldn't be. Do you have anyway to monitor the pressure. After doing any fuel mods, a fuel gauge should be in your future.
Old Dec 25, 2004 | 08:21 PM
b18-c-rx's Avatar
oh yeah, my fuel pressure gauge tells me i'm dead on right now, but i'm planning out my turbo setup, so i dont really know. all i know is that 450cc/min injectors seem to be pushing it in terms of duty cycle, as my calculations show me that i need 500 cc/min for .80 duty cycle.
that is assuming my fuel pressure is 52psi - is this too low, should i plan to run higher?
Old Dec 26, 2004 | 07:50 PM
97hb's Avatar
Default Re: 550 injectors and fuel pump (b18-c-rx)
I am running the 255hp walboro and rc 550s. My duty cycle at 300whp was about 84%. I got a good deal on them, but will be upgrading soon
Old Dec 26, 2004 | 10:44 PM
b18-c-rx's Avatar
Default Re: 550 injectors and fuel pump (97hb)
any rough idle/bad driveability issues?
what kind of deal is this, pray tell
Evans-Tuning.com
Oct 4, 2010 07:08 PM
Evans-Tuning.com
Performance
12
Jun 1, 2009 05:04 PM
TheOdd001
Jun 2, 2008 05:04 PM
b16nonoy
15
Jul 10, 2006 12:29 AM
mike3
Oct 2, 2004 04:52 PM
