DIY - WBo2, Sensor location
Old Dec 29, 2004 | 06:39 PM
civic1990si's Avatar
Default DIY - WBo2, Sensor location
Hi,
I have built a DIY-WBO2. And i want to know where i have to put the sensor???
Right Now it's located 6 to 8 inch after the turbo. The problem i have is when the car idle, it's look that it give me a good output. Seem to be 13.9 to 14.5:1. But when i floor it and go in boost, it's LEAN. And when i said lean is near 20 to 22:1 almost free air. I'm 100% i'm not lean in boost. So Is it possbile that the sensor is too close and gave me a wrong output??? Or it's the WB itself?
Thanks
Old Dec 30, 2004 | 03:02 AM
Default Re: DIY - WBo2, Sensor location (civic1990si)
ttt
Old Dec 30, 2004 | 03:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
dont know if you have a problem or not but aem says 36" away from the exhaust valve in their instructions.
Old Dec 30, 2004 | 06:24 AM
93turbo16's Avatar
I would go no closer than like 18"-20".
Old Dec 30, 2004 | 07:13 AM
Paul_VR6's Avatar
Default Re: (93turbo16)
I had this same problem with my setup, the sensor was too close to the port and would overheat, giving strange readings. The Techedge will actually go into an error mode when this happens, not sure what others do.
For turbo they say that 18" is the min, for NA it's 24" and preferably further in both cases. Depends alot on EGTs.
Tjabo
May 15, 2011 01:29 PM
nfereorhatch
Nov 24, 2008 04:44 AM
ebp_dc2
Jul 16, 2007 06:35 PM
blackeg
Dec 6, 2005 04:26 PM
civic1990si
May 13, 2004 09:15 PM
