Garrett .63 or Precision SC50??? Both almost the same price but which to get???
My friend in sc can get a garrett .63 trim for 550 shipped but someone on ht has the precision sc50 for 595 shipped........Which to choose? arent they the same thing?
Modified by jh at 4:31 PM 12/29/2004
Re: Garrett .63 or Precision SC50??? Both almost the same price but which to get??? (jh)
.63 isn't trim, it's the A/R ratio of the housing to wheel. Did you mean 60-trim vs. 50-trim?
Re: Garrett .63 or Precision SC50??? Both almost the same price but which to get??? (VTC_resurected_
my bad its this then :
GARRETT T3/T04E 57 TRIM W/ .63 A/R TURBINE
all depends on what motor your putting it on and also what kind of powerband you want
the sc34 in precision line is identical to that turbo
The SC34 has a 57 trim wheel (56mm diameter, 2.320" inducer/2.950" exducer) on the compressor side and either a 69 or 76 trim wheel on the turbine side, so there are actually two different versions of the 57 trim.
Also, don't get too hung up on buying a turbo based on the trim size. Compressor trim is a mathematical calculation, which is Inducer Diameter squared divided by Exducer squared X 100. The point is, there's more than one different way to go thru this equation to come up with a 57 trim. Example: 3+3 = 6, 4+2=6, 5+1=6, etc. You can also have different sized wheels with the same trim.
Hope that sheds some light.
Rod Short
Sales Manager
Precision Turbo
Rod Short
Sales Manager
Precision Turbo
underpressure02
02-10-2004 07:26 AM
