Serial adapters for Hondata....???
Old Dec 27, 2004 | 10:25 PM
CivicEJ1's Avatar
Default Serial adapters for Hondata S200....???
Which route should I go since my laptop is too new and doesn't have any serial ports.... the card or adapter...
You guys that have done it before help me out....
Old Dec 27, 2004 | 11:32 PM
shadow103rd's Avatar
Default Re: Serial adapters for Hondata S200....??? (CivicEJ1)
Which Operating system are you using!
Jon
Old Dec 27, 2004 | 11:38 PM
CivicEJ1's Avatar
Default Re: Serial adapters for Hondata S200....??? (shadow103rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow103rd &raquo;</TD></TR><TR><TD CLASS="quote">Which Operating system are you using!
Jon</TD></TR></TABLE>
Windows XP
Old Dec 28, 2004 | 12:08 AM
BoostedJeff's Avatar
I don't know about hondata, but with my AEM, the serial to USB adapter didnt work
Old Dec 28, 2004 | 05:24 AM
b18bturbo's Avatar
Default Re: Serial adapters for Hondata S200....??? (BoostedJeff)
i use the usb to serial adapter and it works fine on my laptop running 2000 pro.
I purchashed the belkin unit
Old Dec 28, 2004 | 05:42 AM
IN VTEC's Avatar
I use a serial-to-USB adapter I bought from Best Buy (roughly $30). I think it's the same one as the one in the picture.
I use a 1.13GHz Sony Vaio with XP home.
ladysman's Avatar
Default Re: Serial adapters for Hondata S200....??? (b18bturbo)
I had issues with 2 different adapters in the early times and finally got the keyspan adapter like Hondata recommends. Never a problem since I got the keyspan. Well worth it. Hondata recommends it for a reason in my book.
http://www.keyspan.com/products/usb/pdaadapter/
Old Dec 28, 2004 | 06:55 AM
PM-Performance's Avatar
Default Re: Serial adapters for Hondata S200....??? (ladysman)
i ran my Hondata off my XP unit. i used a Belkin jawn from Best buy and never had a prob.
Old Dec 28, 2004 | 11:56 AM
CivicEJ1's Avatar
Is the card a good route to take guys?
Old Dec 28, 2004 | 01:07 PM
msmotorsports's Avatar
All I know is that the USB to serial adapter does not work on the AEM units. You will need the PCMCIA serial card to connect. I would suggest try to use the USB adapter and return if it doesn't work. The only disadvantage to the PCMCIA serial cards is that they are alot more expensive and fragile than the USB adapters.
Old Dec 28, 2004 | 02:32 PM
tthame1's Avatar
Default Re: Serial adapters for Hondata S200....??? (msmotorsports)
Hondata recommends using only the Keyspan adapter. It seems to work the best.
PrecisionH23a
Jan 8, 2008 03:59 PM
CaymanNational
Jan 5, 2008 07:33 AM
arrojj
Mar 31, 2007 11:18 PM
SuperSi
Nov 17, 2005 09:08 PM
Suprdave
Jul 28, 2005 12:28 AM
