Turbo heat shield
Old Dec 28, 2004 | 08:46 AM
xrdriver's Avatar
Default Turbo heat shield
I am wanting to save the paint on my hood from all the heat my turbo is going to generate.
What is the best option out there to shield the hood from heat?
I have been looking at a few items:
Like http://www.atpturbo.com/Mercha...e=BCS
OR
http://cgi.ebay.com/ebaymotors...%3AIT
What are you guys using for heat shields?
Cheers!
Old Dec 28, 2004 | 09:31 AM
primeredbeast's Avatar
Default Re: Turbo heat shield (xrdriver)
you could try the exhaust housing wrap that many different companies make thats where most of your heat is going to be generated
Old Dec 28, 2004 | 02:24 PM
underpressure02's Avatar
I haven't heard of many people having problems with their turbo generating to much heat that it hurts the paint.
I got a turbo blanket but it did not seem like it did to much.
Old Dec 28, 2004 | 03:10 PM
StolenTeg's Avatar
Default Re: Turbo heat shield (underpressure02)
Carbon fiber hood
Old Dec 28, 2004 | 04:02 PM
a1320addict's Avatar
Default Re: Turbo heat shield (StolenTeg)
cf hood and heatshield courtesy of xs turbo kit on its way thursday
Old Dec 28, 2004 | 04:09 PM
opto_isolator's Avatar
That ebay auction looks interesting. The blanket looks similar to the insulation that is used on combustion turbines....
And THAT stuff works! The heat really does stay under the blanket...
Old Dec 28, 2004 | 04:13 PM
xrdriver's Avatar
Default Re: Turbo heat shield (opto_isolator)
I have no doubt that the stuff works, but what about turbo longevity?
I remember a few years ago looking into some insulating turbo wrap and it helped the turbo to spool faster as well as keeping all the heat inside the turbo but also killed the seals so that the turbo did not last for very long.
My friend had a turbo d16 in his del sol and the heat from the turbo blistered the paint on his hood.
A CF hood is in my plans for the future, but I would like to shield it from the excess heat also.
Old Dec 28, 2004 | 04:20 PM
MooreBoost's Avatar
I would probably just get the ATP shield. Seems like it would install much cleaner.
Old Dec 29, 2004 | 01:08 AM
turb's Avatar
Default Re: Turbo heat shield (tegunderpressure)
what i did is i bent a thin sheet of aluminum and formed a heatsink and screwed it to the exhaust manifold. underhood temps was considerably lower than without it. it's cheap and it gets the job done.
Old Dec 29, 2004 | 06:37 AM
notoriousB's Avatar
Default Re: Turbo heat shield (slow poke)
I got the ATP heat shield a while back. It looks & fits good, but after a month or so the weld broke and the shield was bouncing around in my engine bay!
I contacted ATP - got an RMA number right away, returned it, got a replacement (GREAT service!!). Installed the replacement, not even 3 weeks later the weld broke AGAIN!!! Instead of returning it (I'm sure they would have replaced it again), I just drilled a couple of holes and mounted it on w/ 2 L brackets and aluminum rivets. Hasn't broken since.
Old Dec 29, 2004 | 06:48 AM
Muckman's Avatar
Moderator in Chief
Default Re: Turbo heat shield (notoriousB)
I cant believe ATP wants $59 for that simple peice of metal.
Old Dec 29, 2004 | 07:29 AM
mildly.interesting's Avatar
I'm buying the wrap....
Old Dec 30, 2004 | 10:33 AM
xrdriver's Avatar
Default Re: (mildly interesting)
Does anyone know of a place that sells the heat shields that shield the hood from the heat off the turbo manifold (log style)
Old Dec 30, 2004 | 12:58 PM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
That is going to lower the heat displacement even more
That is why I am not recommending that product for anything but looks
hey, but it looks GOOD! I got the polished one to match my bling DRAG I/C piping.
My concern was mostly for the the paint on my hood directly above the turbine, not underhood temps. (I removed my hood liner a long time ago)
Old Dec 30, 2004 | 01:34 PM
Frozen E's Avatar
H-T White Ops
$100 for a piece of boiler refractory material and a funny looking pleather case? NO thanks. I'm gonna make my own now.
Old Dec 30, 2004 | 02:41 PM
xrdriver's Avatar
Default Re: Turbo heat shield (IslandSi)
Rember to wear that face mask when working with asbestos
Old Dec 30, 2004 | 02:44 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Rember to wear that face mask when working with asbestos </TD></TR></TABLE>We haven't used asbestos in our refractory for years.
Old Dec 30, 2004 | 09:52 PM
Ace.'s Avatar
Cheap and Easy!!
Simple piece of aluminum that I bet, made bracks for, and then used the existing bolts in the compressor housing to hold it steady...works fantastic...eliminated teh hotspot on my hood, kept the fans from getting melty and looks great...just a bit of elbow polish to shine it up and all done!!
I'm not a fan of the wraps, simply due to the fact that iv'e seen them trap moisture in (after you run it hard, and then let it cool down, it kinda makes it sweat sometimes) anywho, the moisture eventually rusts the entire turbine over and thats not pretty...
EJ8 GSR-T
18
Jan 20, 2006 11:05 PM
Killer_B
Feb 11, 2004 10:34 PM
JrCRXHF
Jan 19, 2004 06:41 AM
Boostless97Lude
Sep 7, 2002 09:04 AM
RATEDR
Jul 4, 2002 12:25 AM
