turbo sir2 problem... please help
Old Dec 30, 2004 | 07:17 PM
eGeeHaTcH's Avatar
Default turbo sir2 problem... please help
i have an sir2 (obd-1) motor and just put a drag gen 3 kit on. as soon as i hit boost, my car feels like it chokes. i was told by a local car shop that its running lean. i dont have any gauges hooked up yet. i am running the drag fmu. i upgraded to a walbro 255lph fuel pump and just put on a b&m fuel pressure regulator and gauge. also have a act stage 1 clutch, everything else is stock. boost is stock 7 lb wastegate. does anyone have any idea why my car feels like this when boost comes on. i've only gone into boost for a split second about 4 times. my idle is also at 2-2500 rpm for some reason, maybe my iac valve? before i put on the turbo, the motor was completely fine. oh yeah and i have a new thermal 3 inch turbo exhaust, it smokes a lot sometimes, i dont know whether thats because its a brand new exhaust or because im having problems. any help would be great. will be installing greddy profec spec 2, hks turbo timer, electric egt, oil pressure, and air/fuel gauges. also thinking of going the cheap route and tuning with a vafc and maybe bigger injectors. thanks, happy new years!
Old Dec 30, 2004 | 08:58 PM
Mr Instigate's Avatar
Default Re: turbo sir2 problem... please help (eGeeHaTcH)
you need injectors!!!
i just ran in to the same problem with my car. i have the same setup i put in 310 injectors. RUNS GREAT!
Old Jan 4, 2005 | 07:34 AM
eGeeHaTcH's Avatar
Default Re: turbo sir2 problem... please help (Mr Instigate)
is your car tuned though? or did u just drop the injectors in and it didn't choke when boost came on?
Old Jan 4, 2005 | 06:55 PM
not tuned. just an FMU and missing link.
Old Jan 4, 2005 | 10:58 PM
PrettyLude's Avatar
for the funny idle, check the iacv, put those elecronics on asap, especially the gauges, ditch the fmu and get hondata
Old Jan 10, 2005 | 09:24 PM
eGeeHaTcH's Avatar
i just put rc 310 cc injectors in and it didnt fix the problem... my car seems like its smoking white smoke (not sweet) almost non stop. in idle and sometimes while normal driving... problems, problems, problems... i need either hondata s100, s200 or apexi vafc2 asap to get tuned
Old Jan 10, 2005 | 09:32 PM
PrettyLude's Avatar
what are you using to control the 310s?
eGeeHaTcH
Jan 16, 2005 02:43 PM
TurboBumblBee
Mar 26, 2004 11:28 AM
GZERO
Jul 28, 2003 10:01 AM
TURBO LS HATCH
Feb 19, 2003 11:43 AM
SOHC_power
Oct 30, 2002 10:10 AM
