ever heard of hks bypass vavle
http://www.hksusa.com/products/more.asp?id=761
just got this today and was wondering has any one used this before
Re: (IslandSi)
im asking if anyone has used this racing bypass valve, i've only seen the ssqv
http://www.hksusa.com/images_products/1271.jpg
Re: (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">what is this "bypass valve" of which you speak?
I would like one, that would be good I think.</TD></TR></TABLE>
ill take a pic later today
Re: (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">I'm pretty sure by-pass valves are for MAF metered cars.</TD></TR></TABLE>
Yup, from the looks of it that HKS BPV can be setup so that the air is routed back into the intake, like most OEM BPV setups. Most BOV's aren't setup like that, they just blow off into the atmospehere. The HKS BPV has a nozzle, that you can attach a hose that you can connect to your intake.
Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">
Yup, from the looks of it that HKS BPV can be setup so that the air is routed back into the intake, like most OEM BPV setups. Most BOV's aren't setup like that, they just blow off into the atmospehere. The HKS BPV has a nozzle, that you can attach a hose that you can connect to your intake.</TD></TR></TABLE>where did u find this info at, so it works as bov just has an extra feature?
Re: (ssrcx94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssrcx94 »</TD></TR><TR><TD CLASS="quote">where did u find this info at, so it works as bov just has an extra feature? </TD></TR></TABLE>
He deduced it simply by looking at it. Any By-pass valve should work as a standard BOV, but not vice versa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">He deduced it simply by looking at it. Any By-pass valve should work as a standard BOV, but not vice versa.</TD></TR></TABLE>
Yup, just like he said, I just guessed it by looking at it. That nozzle can easily make it work as a BPV but it can also work like a regular BOV if you let it vent to the atmosphere. If you look at say an HKS SS BOV and most other BOV's, you wont see a nozzle that you could easily mount a hose to and route back into your intake.
Re: (BlueShadow)
there is an adapter you can buy for the HKS SSQ that allows a hose to be connected to it for rerouting the bypassed air. my friend has one on his MR2.
http://www.hksusa.com/products/?id=798
