compression
Old Dec 29, 2004 | 10:16 AM
89hb's Avatar
Default compression
could someon please tell me the compression on ab18a with itr pistons and a stock head. Is it to much for turboing? thanks
Old Dec 29, 2004 | 10:50 AM
GDM Z28's Avatar
Default Re: compression (89hb)
y dont u do a comp. checl and find out your self?
Old Dec 29, 2004 | 10:53 AM
GDM Z28's Avatar
Default Re: compression (civicflnum1)
if by stock head you meant stock ls head your comp. should be around:
10.3:1 with usdm ITR pistons and about 10.8:1 with jdm ITR pistons. also if you meant stock ITR head its 10.8:1 with the usdm pistons and 11.3:1 with the jdm pistons.
b18bturbo's Avatar
it wil be fine do boost on that low boost probably max on stock block would be around 12psi with a good standalone tune
Old Dec 29, 2004 | 11:12 AM
89hb's Avatar
Default Re: compression (b18bturbo)
are u sure thats not to high? but thanks for the info guys
stonet149
12
Nov 2, 2008 09:29 PM
Ruby Civic
Jul 28, 2002 03:40 PM
vtec8k
Feb 15, 2002 11:32 AM
Stunna BEN
Nov 10, 2001 11:51 PM
Babybluegsr92
Aug 3, 2001 08:18 AM
