Torque for rod bolts?
Old Dec 27, 2004 | 02:31 AM
crispydee's Avatar
Default Torque for rod bolts?
I bought some second hand crower rods and bolts so they came with no manufacturers specs, does anyone know what the torque setting should be? Also is it wise to use any lube on the bolts when assembling. Also does anyone thread lock theres?
Old Dec 27, 2004 | 04:56 AM
snoochtodanooch's Avatar
Default Re: Torque for rod bolts? (crispydee)
buy arp bolts and use the stretch method use the lube that comes with the bolts or moly lube i am guessing.
Old Dec 27, 2004 | 06:07 AM
crispydee's Avatar
Default Re: Torque for rod bolts? (snoochtodanooch)
Will the crower bolts i have not be ok? they are probabley just as good as ARP
Old Dec 27, 2004 | 06:28 AM
b18bturbo's Avatar
i would give crower a call and get the correct specs fo the given bolts and there required torque and stretch readings
Old Dec 27, 2004 | 06:52 AM
crispydee's Avatar
Default Re: Torque for rod bolts? (b18bturbo)
Ha haa i think i will email them as im in the uk and the cost of a phone call to the US will be more than new bolts! good idea i will look them up now.
Old Dec 27, 2004 | 07:36 AM
earl's Avatar
The first anyone would need to know in order to help you is the diameter of the bolt.
Old Dec 27, 2004 | 08:27 AM
crispydee's Avatar
Default Re: Torque for rod bolts? (earl)
they are around 8mm or 5/16"
Old Dec 29, 2004 | 02:10 AM
crispydee's Avatar
Bump as no reply from crower.
Old Dec 29, 2004 | 06:09 AM
b18bturbo's Avatar
which rod is it again ill give them a call for you and get the information
Old Dec 29, 2004 | 06:22 AM
b18bturbo's Avatar
tired calling i know why you didnt get a response is because they are closed for the holidays open up back on jan 3
Old Dec 29, 2004 | 06:48 AM
crispydee's Avatar
Oh right i will wait for there reply then. Thanks for going to the trouble to ring them for me.
Old Jan 2, 2005 | 09:13 AM
crispydee's Avatar
bump, anyone?
Old Jan 6, 2005 | 12:22 PM
crispydee's Avatar
Crower finally got back to me. They said 25ft lbs using engine oil as lube. Does this sound about right?
Old Jan 6, 2005 | 12:25 PM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">buy arp bolts and use the stretch method use the lube that comes with the bolts or moly lube i am guessing. </TD></TR></TABLE>
One can use any type of lube when using the stretch gauge method.
When using a torque wrench one must use the supplied lube which comes with the bolts.
Old Jan 9, 2005 | 01:17 AM
crispydee's Avatar
Default Re: Torque for rod bolts? (dasher)
Ive done a search on the stretch method and it does look to be a lot better. I think i might get a set of new bolts. Just for reference Crower said 25 ftlbs using 10/40 engine oil as lube.
hatchyboy89
Aug 6, 2010 08:11 AM
leem23vtec
Jul 18, 2010 06:58 PM
SOHC_me
Nov 7, 2006 02:05 PM
H22coupe
Apr 30, 2004 05:24 PM
b20ek
Jun 15, 2003 07:02 PM
