Do i need a 3 bar map sensor??
Old Dec 26, 2004 | 05:34 PM
DXK Eg's Avatar
Default Do i need a 3 bar map sensor??
As the title said do i need a 3 bar map sensor if i'm boosting 15psi at the track and yes i did search and found nothing?
Old Dec 26, 2004 | 05:40 PM
adseguy's Avatar
Default Re: Do i need a 3 bar map sensor?? (dynasty-x-motorsport)
Yes anything over over 11 PSI you need a 3bar map sensor.
End of Story
Old Dec 26, 2004 | 06:16 PM
mamaboy's Avatar
atpturbo sells the 3 bar for a fair price
Old Dec 26, 2004 | 06:21 PM
Rod.'s Avatar
Default Re: Do i need a 3 bar map sensor?? (mamaboy)
yep
Old Dec 26, 2004 | 07:38 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Do i need a 3 bar map sensor?? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Yes anything over over 11 PSI you need a 3bar map sensor.
End of Story
BEst said
Old Dec 26, 2004 | 08:17 PM
Dr Pooface's Avatar
End of Story
Technically, anything over 11 psi and you need a 2bar or bigger.
Old Dec 26, 2004 | 08:25 PM
adseguy's Avatar
Default Re: Do i need a 3 bar map sensor?? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
Technically, anything over 11 psi and you need a 2bar or bigger.</TD></TR></TABLE>
You know I knew this was gonna pop up ...but instead of making it complicated and explaining that it's almost the same price and you have room to upgrade I just straight up said go 3bar...LOL . At least your right!
Old Dec 27, 2004 | 11:38 AM
platinum00's Avatar
1 bar of vac 1 bar of boost. so a 2 bar is what he has.
he needs a 3 bar sensor.
1 bar vac. 2 bar boost.
platinum.
Old Dec 27, 2004 | 06:00 PM
warrick's Avatar
Default Re: Do i need a 3 bar map sensor?? (platinum00)
if you are going to be ****, be fully ****.
what he has is a 1.75 bar map sensor.
2 bar would allow him to run 14lbs before maxing out
2.5 bar is 21lbs
3 bar is 28lbs
3.5, 5 etc etc.
Old Dec 27, 2004 | 06:01 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Do i need a 3 bar map sensor?? (warrick)
thats funny , ive ran continuous 13 lb passes on a stock honda map sensor , so it isnt 11 lbs.....
Old Dec 27, 2004 | 06:12 PM
ScottEK's Avatar
Default Re: Do i need a 3 bar map sensor?? (Hella_JDM)
No one said your car is going to stop and blow up, the MAP just does not give a higher signal. Therefore you are not having any additional resolution to tune. You are just carrying on your last value for the 11psi column for all higher boost.
Old Dec 27, 2004 | 10:02 PM
Bailhatch's Avatar
Default Re: Do i need a 3 bar map sensor?? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">No one said your car is going to stop and blow up, the MAP just does not give a higher signal. Therefore you are not having any additional resolution to tune. You are just carrying on your last value for the 11psi column for all higher boost. </TD></TR></TABLE>
exactly, I run 13psi on my 1.75 bar but I "tuned" the 11.x psi column so it's a safe AFR even past the limit of the MAP. I have to run it slightly richer as is passes through 11psi so it ends up OK at 13psi. seems to work fine for quite a while now.
Old Dec 28, 2004 | 04:48 AM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick &raquo;</TD></TR><TR><TD CLASS="quote">if you are going to be ****, be fully ****.
2.5 bar is 21lbs
3 bar is 28lbs
3.5, 5 etc etc.</TD></TR></TABLE>
haha
Old Feb 19, 2005 | 08:12 PM
tegon-gsr's Avatar
damn this is new to me good thing i didnt sell mine my buddy gave me.
Old Feb 19, 2005 | 08:33 PM
u2civic1's Avatar
you will need it if u plan to run hondata or aem ems etc
Old Feb 19, 2005 | 09:57 PM
W O T's Avatar
Default Re: Do i need a 3 bar map sensor?? (u2civic1)
check valves can be your friend
Old Feb 19, 2005 | 11:37 PM
SOHC_MShue's Avatar
Default Re: Do i need a 3 bar map sensor?? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">exactly, I run 13psi on my 1.75 bar but I "tuned" the 11.x psi column so it's a safe AFR even past the limit of the MAP. I have to run it slightly richer as is passes through 11psi so it ends up OK at 13psi. seems to work fine for quite a while now.</TD></TR></TABLE>
yea this is probalby what i would do if I were running 13psi. Anything over 13psi though and I would think it wouldn't run too smooth having to carry out that last column for 11-15psi.
DrivinVtec
Jul 8, 2007 01:01 AM
cigrafix
Sep 19, 2006 04:26 PM
vg7z
Sep 12, 2006 07:20 PM
Topdawgg
Jan 18, 2006 05:15 PM
CaptainMorgan
Jan 27, 2004 04:45 PM
