Ignition setups?
Old Dec 27, 2004 | 05:47 AM
siblues's Avatar
Default Ignition setups?What are you using?
Wanted to know what you guys withhigh boost are using as far as ignition?I was told the oem stuff is good to around three hundred whp but I like to play it safe and just upgrade since it seems stupid to me to blow 4000 dollars on a simple 250 dollar upgrade?
Modified by siblues at 9:18 AM 12/27/2004
Old Dec 27, 2004 | 07:05 AM
siblues's Avatar
Default Re: Ignition setups? (siblues)
Nobody wants to chime in ?
Old Dec 27, 2004 | 08:28 AM
beepy's Avatar
That is a very variable question, which is why you didn't get a specific answer.
Mostly it depends on the technology the car is already equipped with.
The majority of Honda owners can just gap the plugs down, go a step colder on the heat range, retard the dizzy a few degrees and call it a day. If that is not good enough, though, you can easily go with a MSD Digital SCI and Blaster coil and have all the spark energy you will ever need. If you are going to spend the bucks, get something with boost-dependant ignition retard functions.
If however you have a 1.7, the MSD DIS-4 is a great way to go. MSD even makes a model with boost retard AND a extra injector controller built in.
Old Dec 27, 2004 | 08:31 AM
SpoolnG2's Avatar
Default Re: Ignition setups? (beepy)
I think i might be trying out the Digital 7 w/ an HVC coil this year. Kinda pricey but its good stuff.
Old Dec 27, 2004 | 08:45 AM
siblues's Avatar
Default Re: Ignition setups? (SpoolnG2)
I know that it was a pretty general question but it seems to me that here on h-t people sometimes seem to get really good results from not your everyday setups so I just pretty much wanted to here about all the different setups everyone is using?You know anything from stock to coil on plug conversion. Sorry about it being such a generic question (no sarcasm intended)
Old Dec 27, 2004 | 12:31 PM
tgreaves's Avatar
I was running a MSD SCI with a MSD BlasterSS coil and MSD 8.5mm plug wires.. My new setup that im building will use 2 MSD SCI boxes and 4 cbr coils(wastefire)..
Old Dec 27, 2004 | 11:25 PM
PrettyLude's Avatar
Default Re: Ignition setups? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I was running a MSD SCI with a MSD BlasterSS coil and MSD 8.5mm plug wires.. My new setup that im building will use 2 MSD SCI boxes and 4 cbr coils(wastefire)..</TD></TR></TABLE>
post up some pics when your done
Old Dec 28, 2004 | 05:52 AM
tgreaves's Avatar
Default Re: Ignition setups? (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">
post up some pics when your done</TD></TR></TABLE>
Sure will.. Im not sure if im going to use the 4 cbr coils or 2 dual post Nology coils(leaning more tword the Nology coils but we will see).. Either way ill post pics of it soon..
Old Dec 28, 2004 | 07:27 AM
PrettyLude's Avatar
i was to do a setup like that, just waiting on pics to see how to do it
Old Dec 28, 2004 | 07:32 AM
tgreaves's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i was to do a setup like that, just waiting on pics to see how to do it</TD></TR></TABLE>
You really need a multi coil ecu in order for it to be of any use..
PARADOX_sf
Jan 31, 2012 05:55 AM
AJxr
Dec 14, 2005 08:20 PM
^jefs0ng
Oct 28, 2003 02:53 PM
Bspec18
Jun 30, 2003 12:55 PM
