4inch Exhaust..Is it worth it??
Old Dec 28, 2004 | 05:47 PM
jdmfun99's Avatar
Default 4inch Exhaust..Is it worth it??
Does it make a big diff. if you run a 4in rather then a 3in exhaust??what are the benefits..i know less back pressure but is it really worth it??
Old Dec 28, 2004 | 05:49 PM
drift2004's Avatar
Default Re: 4inch Exhaust..Is it worth it?? (jdmfun99)
to big
Old Dec 28, 2004 | 05:51 PM
underpressure02's Avatar
lhow much power do you want to make? How big of turbo are you running?
Old Dec 28, 2004 | 05:53 PM
pimpintyperintegra's Avatar
it would be worthwhile if your turbo is very large and you are looking to make a lot of power
Old Dec 28, 2004 | 05:57 PM
CivicEJ1's Avatar
Yeap...too big....it won't clear any thing unless you plan to be looking like a 4x4...
Old Dec 28, 2004 | 06:00 PM
Default Re: 4inch Exhaust..Is it worth it?? (CivicEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeap...too big....it won't clear any thing unless you plan to be looking like a 4x4...</TD></TR></TABLE>
I don't agree with that statement care to explain how it won't clear anything with out jacking up your car?
Old Dec 28, 2004 | 06:01 PM
1fastgsrturbo's Avatar
Default Re: (pimpintyperintegra)
(not trying to jack your thread) i was wondering the same thing. If you are running the full-race top mount and you run the 4 inch downpipe, wouldnt it make since to run a 4 inch exhaust? Would you have the 4 inch downpipe and hook it up to your 3 inch until you go to the track and run open down pipe? Oh yeah and shooting for the 650whp with a t3/t67 w/ p wheel.
Old Dec 28, 2004 | 06:10 PM
Default Re: (1fastgsrturbo)
for your application, a 4" downpipe is not really necessary to make the power, but I would use the 4" if I were you because it should make a little more power and the turbo will spool faster
I am going to use a 4" downpipe and I am going for 800+whp
It is probably best to either run downpipe dumped all the time or hook it to a 3" exhaust for street, because a 4" pipe will not fit very well all the way back.
Old Dec 28, 2004 | 06:14 PM
TeamNextGenChris's Avatar
why not just run an electric cutout or some other kind of dump?about 4-5" after my downpipe bolts to the turbo,i have an electric cutout with a 3" turndown coming off it.doesn't get much freer flowing than that.you can still have a quiet exhaust for cruising around,and no restriction at all when you need it.i think they even make a 4" version if you want to go that extreme.
Chris
Old Dec 28, 2004 | 06:21 PM
So basically if i were to switch to the top mount i should use the 4inch downpipe and just keep my 3 inch exhaust. Then when i go to the track run open down pipe. Thanks i didnt want to go through the head ache of switching exhaust, plus this is still a street car that i drive often. So 4 inch exhaust is overkill for any (true) street car. And if you are not shooting for 750+ then dont bother, right
Old Dec 28, 2004 | 06:35 PM
my opinion is that when you are shooting for 600+whp that a 4" downpipe is a good idea but not totally necessary unless you want to get as much power as possible
I will probably drive mine around with the 4" dp dumped, but I also have a 3" exhaust that I can hook up if I want to.
Basically if you have a 700+whp honda, you probably really don't give a **** about street legal status even if you drive it on the street. I really don't care myself.
The issue with having a 4" exhaust that goes all the way back is clearance. It really won't fit all that well and will rub and clank on things if it fits at all.
Unless you have a Supra or something.
Old Dec 28, 2004 | 06:58 PM
T4eg's Avatar
some examples we did exhaust on my friends car... we dynoed it open 3" downpipe then made 4" exhaust from the DP back and redynoed and made more power.
I am running 4" from the turbo back on my street car
Chris
Old Dec 28, 2004 | 07:21 PM
scoop's Avatar
check this out
https://honda-tech.com/zerothread?id=1032331
Old Dec 28, 2004 | 08:15 PM
jfoster's Avatar
I have a 4" 90* bend/turn down for sale or trade if anyone is lookin for a cheapy -&gt; https://honda-tech.com/zerothread?id=1095277
Old Dec 28, 2004 | 08:17 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 4inch Exhaust..Is it worth it?? (jfoster)
as soon as i saw jfoster i knew this was what you posted, lol
Old Dec 28, 2004 | 08:31 PM
jfoster's Avatar
Default Re: 4inch Exhaust..Is it worth it?? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">as soon as i saw jfoster i knew this was what you posted, lol</TD></TR></TABLE>
Hey, you gotta give the people what they want
Seriously though, if you're runnin enough horses to need 4" exhaust you're probably not streetable....so you might as well just run 4" open down pipe.
Old Dec 28, 2004 | 09:22 PM
10secivic's Avatar
When i first started i ran the 3 inch and i used to trap 124 ish and when i would run open exhaust i would trap 128 ish. As soon i ran full 4 inch it went back up to 128 so for me on the 4 inch
Old Dec 28, 2004 | 09:30 PM
LoSt is BlaCk's Avatar
Default Re: 4inch Exhaust..Is it worth it?? (10secivic)
have fun with that on the street
Old Dec 28, 2004 | 09:42 PM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10secivic &raquo;</TD></TR><TR><TD CLASS="quote">When i first started i ran the 3 inch and i used to trap 124 ish and when i would run open exhaust i would trap 128 ish. As soon i ran full 4 inch it went back up to 128 so for me on the 4 inch
What kind of HP are you making? 4" DP too? Hmmm.....maybe I should consider 4" exhaust for my street/strip teg
Old Dec 28, 2004 | 09:50 PM
This One's Avatar
I dont see the point in this 4" craze.
people make numbers all day on 3". There's many full race cars out there on full 3" exhuast setups. I remember a post a whle back about someone making over 400 on a 2.25" exhuast setup.
4' is alot to stuff under a civic, 3.5 is just as bad
Old Dec 28, 2004 | 09:53 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpintyperintegra &raquo;</TD></TR><TR><TD CLASS="quote">for your application, a 4" downpipe is not really necessary to make the power, but I would use the 4" if I were you because it should make a little more power and the turbo will spool faster
It is probably best to either run downpipe dumped all the time or hook it to a 3" exhaust for street, because a 4" pipe will not fit very well all the way back.</TD></TR></TABLE>
why use an exhaust if your goin for 8000+ whp? obviouslty itns not gonna be a street car
Old Dec 29, 2004 | 01:09 AM
KTeller8's Avatar
Default Re: 4inch Exhaust..Is it worth it?? (This One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by This One &raquo;</TD></TR><TR><TD CLASS="quote">I dont see the point in this 4" craze.
4' is alot to stuff under a civic, 3.5 is just as bad</TD></TR></TABLE>
3.5" isnt that tough if properly done right
example:
Old Dec 29, 2004 | 09:21 PM
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
why use an exhaust if your goin for 8000+ whp? obviouslty itns not gonna be a street car</TD></TR></TABLE>
you're right
that's why I am going to run the 4" downpipe dumped even though I do drive it on the street. It isn't exactly a daily driver though, more of a when I want to drive it car.
but I already have a 3" exhaust that I could use if I feel like it.
i am going for 800 not 8000
Old Dec 30, 2004 | 12:44 AM
SOUNDEFFECTS's Avatar
800 is alot my friend. What kind of times are you going for? on just gas?
Old Dec 30, 2004 | 05:24 PM
Default Re: (SOUNDEFFECTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOUNDEFFECTS &raquo;</TD></TR><TR><TD CLASS="quote">800 is alot my friend. What kind of times are you going for? on just gas?</TD></TR></TABLE>
i am looking to smoke modded bikes, vettes, vipers, supras, exotics, etc. on the highway and run good times in the 1/4 as well
not looking to be a 1/4 only car
yes it will be just gas (c-16)
i'll have nitrous to spool the turbo (SP71 GTQ), but the nitrous will cut off at certain boost
big turbo, c-16, built motor, 35+psi, bad *** tuning make a fast integra
Motec to run all this
