Spearco Intercooler Too Small?
Old Dec 29, 2004 | 11:27 PM
Tchleung's Avatar
Default Spearco Intercooler Too Small?
I have a Spearco IC. Core is 18"x6"x3" Bar and plate Small intercooler. Does anyone know what power these are good for before it becomes unefficent? My next setup is gonig to be atleast 350-400WHP. maybe more. Would this be too small??
Modified by Tchleung at 6:27 PM 12/30/2004
Old Dec 29, 2004 | 11:33 PM
integlspwr2k's Avatar
Default Re: Spearco Intercooler Too Small? (Tchleung)
that thing looks unefficent already...
who runs small fmic's like that?
Old Dec 29, 2004 | 11:51 PM
elitesi8's Avatar
That thing looks like it would be way to small for anything over 10hp , haha
Old Dec 30, 2004 | 01:21 AM
Default Re: Spearco Intercooler Too Small? (elitesi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elitesi8 &raquo;</TD></TR><TR><TD CLASS="quote">That thing looks like it would be way to small for anything over 10hp , haha</TD></TR></TABLE>
10hp?
thats like wayyyy heat soak already ...
i was thinking more like 5hp and its border line efficent / heat soak...
Hell..
I think he is better running a pipe right across the front where the FMIC would be, probally have the same cooling characteristics then that FMIC.
Old Dec 30, 2004 | 01:24 AM
YashiMotors's Avatar
It is little bit to small for over 300hp... but it depends on the thicknesss allso...check out a stock Supra MK4 IC it isn't so big but works quite good with BPU that is 450hp.
Old Dec 30, 2004 | 08:17 AM
Tchleung's Avatar
Crap lol. I had a feelnig you guys would say it.
Old Dec 30, 2004 | 08:24 AM
Sohc Driver's Avatar
Default Re: (Tchleung)
thats about the size of the precision intercooler that is rated at 350hp.
Khoi
Old Dec 30, 2004 | 08:42 AM
97hxturbo's Avatar
Damn thats small
Old Dec 30, 2004 | 08:45 AM
Tchleung's Avatar
Default Re: (Sohc Driver)
Except my core is only 18" the 350HP one is 26" from Precision. but I was looknig around and there are some name brand companies taht rate their intercoolers even higher then 350hp yet are only 20"x6"3"
My specs are:
Core:
18"L
3"W
6"H
Old Dec 30, 2004 | 08:47 AM
TheShodan's Avatar
Moderator
Well, you've got it in your possesion. Only thing to do is to try it out and find out..
Old Dec 30, 2004 | 08:49 AM
Tchleung's Avatar
Good point yeah...
Old Dec 30, 2004 | 08:53 AM
onefstek's Avatar
do you have a problem with the intercooler you have now? if not then don't worry about it.
Im running an cheap ebay fmic with about the same size and making 400 whp and the temps are still decent.
as long as you don't detonate and your temps are stable you should be good to go.
A bigger fmic would be better but that is up to you........98ctr
Old Dec 30, 2004 | 09:13 AM
Tchleung's Avatar
what is your intake charge temps? I don't really have a way to check my intake charge temps via ecu or probe. It seems fine but 4th and 5th gear do seem to lag a bit compared to 1/2/3. but that could jsut be because opf the logner gears... I need a ride in another turbo honda to see how it feels heh.
Old Dec 30, 2004 | 09:34 AM
Blackack26's Avatar
my pwr core is 18x6x3 and is rated for ~350hp....
Doesn't look as small as yours for some reason though *shrug*
2.2XDreams's Avatar
reminds me of the front mounts on the new turbo miatas...
Old Dec 30, 2004 | 09:39 AM
VTC_CiViC's Avatar
Default Re: (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">my pwr core is 18x6x3 and is rated for ~350hp....
Same here, getting rid of mine for a Precision 750
Old Dec 30, 2004 | 09:50 AM
mattssi's Avatar
So let me get this straight? the efficiency of the unit is directly attributed to the size of the unit? Sound familiar?
Old Dec 30, 2004 | 09:53 AM
Tchleung's Avatar
No ours look the same size about. jsut our end tanks are differnet. yours onyl has that angled spot at the top. then it gpoes straight down doesn't it? Mines has angles on both sides kinda thing. hard to explain hehe. but if you compare pics. our cores goto the same spot. roughyl under the middle of the fog.
Old Dec 30, 2004 | 10:04 AM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">No ours look the same size about. jsut our end tanks are differnet. yours onyl has that angled spot at the top. then it gpoes straight down doesn't it? Mines has angles on both sides kinda thing. hard to explain hehe. but if you compare pics. our cores goto the same spot. roughyl under the middle of the fog.</TD></TR></TABLE>
Yeah I see what your saying... I actually painted my couplers and clamps black so it blends in, that's why you can't see the outlets.
Old Dec 30, 2004 | 10:14 AM
Tchleung's Avatar
ah Cool. you know I should jsut email Spearco.
Old Dec 30, 2004 | 10:18 AM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">what is your intake charge temps? I don't really have a way to check my intake charge temps via ecu or probe. It seems fine but 4th and 5th gear do seem to lag a bit compared to 1/2/3. but that could jsut be because opf the logner gears... I need a ride in another turbo honda to see how it feels heh.</TD></TR></TABLE>
I have constant air temps in the intake mani, about 28 to 32 deg celsius so about 82.4 to 89.6 deg farenhight during the summer months. it drops down to about 10-15 deg C in the winter months. 98ctr
Old Dec 30, 2004 | 10:51 AM
ITR981002's Avatar
DSM guys make 300whp with 16g turbos (small compared to the T3/T4s I see on most Hondas) and sidemount intercoolers that are 3 times smaller than that. Bigger would probably be better, but I don't think that IC is going to hurt you as much as some would lead you to believe.
Old Dec 30, 2004 | 11:03 AM
fernancivic's Avatar
No Sales Forums
maybe these will help
https://honda-tech.com/zerothread?id=1097534
Old Dec 30, 2004 | 04:44 PM
Default Re: Spearco Intercooler Too Small? (CentralFloridaTurbo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CentralFloridaTurbo.com &raquo;</TD></TR><TR><TD CLASS="quote">maybe these will help
https://honda-tech.com/zerothread?id=1097534</TD></TR></TABLE>
Even cheaper...
http://cgi.ebay.com/ebaymotors...&rd=1
Old Dec 30, 2004 | 04:59 PM
80884's Avatar
Default Re: Spearco Intercooler Too Small? (integlspwr2k)
small doesn't mean it isn't good. they rate that one at 760hp, flows 1080cfm. 3.5"Dx18.48"Wx6"H
