Where to mount Inline Fuel Pump?
As the subject says, I wanted to know where you guys mount the inline pump? My Brother just put a Turbo Kit on his Integra and he asked me for help installing the Inline Pump. Any Help will be appreciated... Pics would be Great!!!
Edgar
Edgar
Don't you have to put it after the fuel filter... between it and the fuel rail? I recall reading something like that... Anyhow, I followed suite... and did such... and mounted (zip tied) it to the A/C hard lines... Just under the fuel filter...
I don't like it... I am thinking about mounting it elsewhere...
How long can the lines be to an from the pump? Would that even make a difference...
I'm interested in see where other have mount there also...
edit: I had ask the same question too...
https://honda-tech.com/zerothread?id=966738
This is what someone replied.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">Why not make your lives easier and get a Walbro GSS-342 HP 255lph "intank" fuel pump for under $100?</TD></TR></TABLE>
Thats what I would do. But if you do go for an inline mount it the way scartail did.
inline pumps suck ***, they only help to get fuel pressure up a bit, 9 times out of 10, they flow alot less volume then your stock unit, AND they will only be fed as fast your intank pump can feed them!!!!! so whats the point, buy a good intank pump for 100 bux, or less and forget about it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">inline pumps suck ***, they only help to get fuel pressure up a bit, 9 times out of 10, they flow alot less volume then your stock unit, AND they will only be fed as fast your intank pump can feed them!!!!! so whats the point, buy a good intank pump for 100 bux, or less and forget about it</TD></TR></TABLE>
7PSiEF9ZC
Jun 14, 2003 07:38 AM
slwazgsr
Oct 12, 2002 07:37 AM
