dyno question
Old Dec 27, 2004 | 11:05 AM
dAng! Kris's Avatar
Default dyno question **UPDATED*
I have a 95 gsr w/ PnP head, skunk2 valves, springs, retainers, jg 65mm tb, port matched IM, comectic high boost head gasket, arp head studs, t3/t04E .57 trim .63 A/R. 2.5'' DP, 3'' exhaust, no cats, log mani, tial wg, gredy type-s bov.
On 10 psi i man 254hp/205tq is that about right. He said it was tuned conservitavly and it started to have a leaking head gasket(when i had the stock hg, the comectic is now brand new and hasnt seen the dnyo yet).
Should I expect a little better numbers or should i up the boost a couple psi( btw its a stock gsr block)?
Thanks
Modified by Frozty at 8:38 AM 12/31/2004
Old Dec 27, 2004 | 11:31 AM
VTC_CiViC's Avatar
Default Re: dyno question (Frozty)
Kinda low. Typical 10psi GSR will see 280whp +/-, guess it was tuned ultra-conservativley.
FWIW, stock IM, 2.3" exahust and I made 244 or 246 @6psi on Hondata, conservativley tuned by SFP.
Old Dec 27, 2004 | 11:32 AM
underpressure02's Avatar
That seems low. My friend had the same setup but only 2.5 exhaust and made 250 something at only 5.5 psi on a totally stock gsr with hondata s200
Old Dec 27, 2004 | 12:02 PM
Benjithx's Avatar
Default Re: dyno question (underpressure02)
why all the $ in the head and not in the block where you really need it?
Old Dec 27, 2004 | 12:26 PM
tgreaves's Avatar
Default Re: dyno question (Benjithx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">why all the $ in the head and not in the block where you really need it?</TD></TR></TABLE>
I agree.. It would suck for you to break a rod and damage that head with all that work done to it..
Old Dec 27, 2004 | 07:31 PM
dAng! Kris's Avatar
Default Re: dyno question (tgreaves)
it was tuned VERy conservitavly. Getting new numbers tomorrow with new gasket. I'm not gonna sqeeze max numbers because its my daily driver for the enxt few month.
The head is off my other gsr engine which is currenty being built for turbo.
But thanks for the imput guys, I'll give you a update tomorrow
Old Dec 27, 2004 | 07:47 PM
evosol's Avatar
i agree it does seem kinda low... especially with the head job. i tuned a stock 2000 gsr, drag kit, 550s and Uber. street tune base run was 253WHP 198TQ... we left it at 271WHP, 200TQ because my buddy wanted a conservative tune. 20.5 total timing @10psi... i dunno... it was my first time tuning on a dyno... he was happy though. i'm sure you'll see better numbers and still be safe.
Old Dec 30, 2004 | 11:39 PM
dAng! Kris's Avatar
Default Re: dyno question (evosol)
got the car back, i made 243hp/205tq @ 8psi conservitave tune. but yea I'm very happy with the car. pulls really hard through power band. I dont have a scanner to post graph but tonite i put 6 cars on a 03 C5 vette from 70 punch
Old Dec 31, 2004 | 01:58 PM
evosol's Avatar
nice!
Old Dec 31, 2004 | 02:12 PM
turboEGhatch's Avatar
243 @ 8 psi would be low for a stock GSR, and especially one that has a fully ported head. A very low AFR and tons of timing pulled out can be just as bad as running too lean with too much timing, so make sure he isn't going "too conservative". You could wash down the cylinder walls with fuel, and all the timing he pulled could cause skyrocketing EGT's which isn't good for anything.
Old Dec 31, 2004 | 02:49 PM
MooreBoost's Avatar
Default Re: dyno question (turboEGsedan)
I would switch to the MLS gasket, alot of people dislike the HP.
Spent
Jun 25, 2010 06:43 PM
92LSVTEC
Apr 7, 2007 11:06 AM
WalkerGSR1
Oct 25, 2006 04:12 PM
Civic92Turbo
15
Dec 24, 2004 12:23 PM
servion
Oct 20, 2002 10:37 PM
