piston to wall clearance
Old Dec 27, 2004 | 12:33 PM
LSVtechnologytur...'s Avatar
Default piston to wall clearance
hey i was doing some research and the piston to wall clearance, and for arias pistons does .002 - .003 sound right for a turbo setup? just double checking before i go to the machine shop.
TIA
Old Dec 27, 2004 | 12:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: piston to wall clearance (vtec'n)
Your pistons should come with a spec sheet for all that. Id trust the manufacturer before I trusted some guy on the internet. But .003" sounds right, thats what I used for my CPs.
Old Dec 27, 2004 | 01:30 PM
Default Re: piston to wall clearance (Muckman)
alright thanks
Old Dec 27, 2004 | 01:45 PM
B20luda's Avatar
i used .003 on my JE's
Old Dec 27, 2004 | 02:55 PM
Jared's Avatar
Default Re: piston to wall clearance (B20luda)
it depends on how much hp you plan on making
Old Dec 27, 2004 | 05:14 PM
93LSivic's Avatar
Default Re: piston to wall clearance (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">it depends on how much hp you plan on making</TD></TR></TABLE>
Also depends on what material the piston is made out of.
Ive gone as high as .005" on JE's (slightly noisy though) and CP's for the most part use .0035" of piston to wall which is built into the piston.
Call Arias and tell them how much boost and rpm you plan on running and they will recommend the proper cylinder to wall spec for you.
Hope this helps.
Old Dec 27, 2004 | 05:37 PM
SOUNDEFFECTS's Avatar
Wiseco I believe recommends .0029 clearance, Je .003 sounds ok. I have seen rediculous piston to wall clearance around .008-.0012 on a methanol motor that worked good. So I mean it all depends on the power level, and what kind of life this thing is suppose to have.
Old Dec 27, 2004 | 05:45 PM
dasher's Avatar
depends on the piston,the silicone content theirin, and desired whp levels.
Check with your piston manufacture.
Most low-silicone forged aftermarket pistons like 0.003" to 0.0035" for forced induction applications under moderate whp applications.
Old Jan 6, 2005 | 05:46 AM
SnOOpY-NO's Avatar
Default Re: piston to wall clearance (dasher)
when u say 0.003"... Is that the total clearance or just on one side of the piston???
Old Jan 6, 2005 | 05:57 AM
dasher's Avatar
Default Re: piston to wall clearance (SnOOpY-NO)
This means that the bore diameter of the cylinder is 0.003" larger then the diameter of the piston. Yes, its a tight fit!
AaronJ
May 1, 2008 05:42 PM
litovi3tboi503
May 11, 2007 09:12 AM
Sport_Injected
Jul 29, 2004 03:15 AM
onetwothree
Jul 8, 2003 06:25 AM
