MAP BYPASS? ASAP
Old Dec 27, 2004 | 05:28 PM
CAE's Avatar
CAE
Default MAP BYPASS? ASAP
HI, GUYS I NEED HELP ON HOW TO INSTALL THAT BASIC MAP SENSOR BYPASS,MY ? IS I DON'T KNOW WHICH,AND WHERE WHICH THE HOSE GOES,PLEASE HELP ME A NEED AS SOON AS POSSIBLE, THANK U THANK U THANK U
OH BY THE WAY I HAVE THE SAME QUESTION ON THE FMU.
Old Dec 27, 2004 | 05:43 PM
T304 lude's Avatar
Default Re: MAP BYPASS? ASAP (CAE)
Do you mean the Synergy Missing Link that you need to fit to the Standard MAP sensor??
Old Dec 27, 2004 | 06:13 PM
CAE's Avatar
CAE
Default Re: MAP BYPASS? ASAP (T304 lude)
YES,THATS THE ONE BUT I HAVE THE ONE THAT U CAN BUY FROM A PET STORE IT THE NAME OF IT IS TETRA,I THINK
PLEASE SOMEONE HELP ME WITH THIS PROBLEMO
Modified by CAE at 7:36 PM 12/27/2004
Old Dec 27, 2004 | 07:29 PM
tegasaurus's Avatar
i think you're thinkin of a check valve if you purchased it from the petstore.
is it an aluminum block? if not, skip to the next paragraph. on top of your throttle body, there is your map sensor (held in by 2 screws, there is a plug also attached to the map sensor. unscrew those screws, and place the metal piece inbetween the sensor and the throttle body, use the new supplied longer screws.
If it is just a type of valve, cut the line going to the barb fitting under the map sensor, and splice the device into the line.
Old Dec 27, 2004 | 08:35 PM
CRXdan's Avatar
insatll a 3 way tee inline with the map/TB and install the check valve onto one end of the tee. Make sure air can escape the assembley, but u cant blow air in.
Old Dec 27, 2004 | 09:03 PM
PrettyLude's Avatar
Default Re: MAP BYPASS? ASAP (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T304 lude &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean the Synergy Missing Link that you need to fit to the Standard MAP sensor??</TD></TR></TABLE>
its a synaspe missing link
Old Dec 28, 2004 | 02:08 AM
JRciv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAE &raquo;</TD></TR><TR><TD CLASS="quote">YES,THATS THE ONE BUT I HAVE THE ONE THAT U CAN BUY FROM A PET STORE IT THE NAME OF IT IS TETRA,I THINK
Modified by CAE at 7:36 PM 12/27/2004</TD></TR></TABLE>
There's no need to shout.
Old Jan 4, 2005 | 04:52 PM
CAE's Avatar
CAE
hey guys here is a new check valve that i found it work alot better than that u buy from a petstore, here is the link if u want look at it.
http://www.napaonline.com/cgi-...=5806
let me know if the link don't work.
allnaturalb16
Oct 19, 2007 10:14 PM
Carbcivic
Mar 14, 2007 05:55 AM
turbojdm521
Jun 12, 2003 11:29 AM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
