Vaccum line
Old Dec 29, 2004 | 11:12 PM
mooook's Avatar
Default Vaccum line
where is a good source for vaccum on the intake manifold?
i need to move my boost controller line that is on the compressor side of the turbo. I do not want to tap into where the BOV and FPR are.
suggestions?
Old Dec 30, 2004 | 03:34 AM
FredoSP's Avatar
Default Re: Vaccum line (mookvtec)
do you have any "open" ports on the IM? I know cruise control uses a VAC line, easy fix would be to use that tap off the IM if u don't use cruise cotrol.
Some might suggest you buying/making a vaccum box/manifold and tap it from the brake booster, I personally aren't a fan of it.
Old Dec 30, 2004 | 08:46 AM
mooook's Avatar
Default Re: Vaccum line (FredoSP)
i thought about doin a vaccum bar but i just dont know.
Im thinkin about tapping into the cruise control line or the brake booster?
Old Dec 30, 2004 | 08:49 AM
RyanEJ8's Avatar
I'm going to run a vacuum box off of the 3/8" nipple on my intake manifold that used to be for the PCV line.
Old Dec 30, 2004 | 10:33 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mookvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Im thinkin about tapping into the cruise control line or the brake booster?</TD></TR></TABLE>
Now that I think about it, I'm not sure how strong that VAC signal is, but I'm sure it will be sufficient, give it a try.
Old Dec 30, 2004 | 10:51 AM
mooook's Avatar
i just talked to my buddy im gonna hook it up to the brake booster when i get a damn T fitting.
Old Dec 30, 2004 | 10:54 AM
Tad's Avatar
Tad
cant you just stick a t fitting into any one of the gazillion vacuum lines running around back there?
99delsol
Sep 20, 2006 06:57 PM
FredoSP
Apr 12, 2004 09:21 AM
ClubSiRacer
Nov 12, 2003 05:10 AM
redhatchb18
Oct 23, 2003 10:27 AM
Nextelbuddy
Aug 26, 2003 10:37 AM
