compression test results sound low
Old Dec 27, 2004 | 04:11 PM
crxvtecturbo's Avatar
* B A N N E D *
Default compression test results sound low
i did a compression test on my motor at wot do these numbers sound good or is it time for a rebuild my setup b18c long block 20 over 9:5:1 wiseco pistons eagle rods or am i ok to keep boostin it?
cyl#1 170
cyl#2 170
cyl#3 170
cyl#4 168
Old Dec 27, 2004 | 04:24 PM
quickergixxer's Avatar
Default Re: compression test results sound low (crxvtecturbo)
my 9:1 motor is good for 180 but i hold it wot and go till it stops rising.
im sure your fine
Old Dec 27, 2004 | 04:39 PM
mrbsponge's Avatar
man my B16 is only 140 all the way across, but i was shooting for 8.5:1
Old Dec 27, 2004 | 04:56 PM
Dr Pooface's Avatar
Default Re: (mrbsponge)
The numbers depend on many variables, the important thing is that they are all within 5% of each other.
Old Dec 27, 2004 | 05:14 PM
StolenTeg's Avatar
Default Re: (Dr Pooface)
Last time i check the compression of my motor it was at 220 190 190 220, this is on a B18b1 Ls engine. I was suprised by the high number, the motor had about 700 miles on it after a rebuild with 9.5 wesico piston and eagle rod, there over 2k miles on the engine now and i havent check to see how the compression is yet.
Old Dec 28, 2004 | 03:39 PM
* B A N N E D *
Default Re: (StolenTeg)
ttt
Old Dec 28, 2004 | 03:57 PM
b18bturbo's Avatar
Default Re: (crxvtecturbo)
as long as they equal across the board and there is no buring of oil or any other issues then keep boosting and enjoy it
Old Dec 28, 2004 | 04:50 PM
adseguy's Avatar
Default Re: (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">as long as they equal across the board and there is no buring of oil or any other issues then keep boosting and enjoy it </TD></TR></TABLE>
your fine
Old Dec 29, 2004 | 05:12 PM
* B A N N E D *
Default Re: (adseguy)
ttt
Old Dec 29, 2004 | 05:22 PM
Sonny's Avatar
You've had 3 people here tell you that you're ok. What else do you want? Do you want us to tell you that your engine is screwed?
Sonny
swappedsieg
Dec 14, 2013 10:30 AM
fast2camciv
Aug 31, 2007 09:23 PM
mugenhatchie
Apr 3, 2006 12:31 AM
spooncivic28
10
Dec 19, 2005 11:58 AM
sdinteg
Feb 1, 2005 07:52 PM
