Best D Series Transmission for FI and Drag Racing
I've searched, but to no avail. I've heard lots of input on which B series tranny is the best, but what I want to know is which of the D trannies is best suited for a turbo D on the track. Z6, Y8 maybe?
This would be for a car running 22" slicks.
Re: Best D Series Transmission for FI and Drag Racing (beerbongskickass)
What's the difference between the Y8 and the Z6 other than the Y8's are bound to have a lot less miles on them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">The Y8 has steel shifter forks and the Z6 has aluminum shifter forks.
Re: Best D Series Transmission for FI and Drag Racing (tgreaves)
Yeah, I need a hydro tranny.
So are the gear ratios the same in the Y8 and Z6?
Also, I just picked up a spare Z6 tranny sinse I'm starting to get some pretty bad 3rd gear grinding. Can I retrofit the steel shifter forks if I can find some? I'm thinking I'm just gong to do a rebuild before I throw this one in.
Re: Best D Series Transmission for FI and Drag Racing (Ibiza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza »</TD></TR><TR><TD CLASS="quote">
So are the gear ratios the same in the Y8 and Z6?</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza »</TD></TR><TR><TD CLASS="quote">Can I retrofit the steel shifter forks if I can find some? I'm thinking I'm just gong to do a rebuild before I throw this one in.</TD></TR></TABLE>
Y8 forks will not fit in the Z6 tranny.
Yes
Re: Best D Series Transmission for FI and Drag Racing (RyanCivic2000)
Quick question, how would you know when the shifter forks in your Z6 tranny are going bad or failing?
Re: Best D Series Transmission for FI and Drag Racing (_Edge.ONE)
notstreetlegal
04-10-2007 09:49 AM
