What else do i need?
Old Dec 30, 2004 | 06:28 PM
00situner's Avatar
Default What else do i need?
I have just found this kit for my 2000 Si and i think this is the way i am going to go i was just wondering what else i will need to make it complete i already have hondata S200 and i am buying injectors and a inline fuel pump is there anything elsTial 38mm wastegate
-PWR 24x6x3.5 Intercooler (2.5" inlet and outlet)mounts directly to factory bumper support
-Tial blow off valve
-12inch "Slimline" pusher radiator fan
-Vortech FMU
-fully TIG welded complete 3 peice 2.5" charge piping (no modifications necessary)
-3inch downpipe with stainless flex section and wastegate dumptube.
-Stainless oil feed (-4) and oil drain (-10) lines (featuring earls fittings.)
-Weldless oil drain line
-All necessary couplings
-Strong T-Bolt hose clamps
-all necessary gaskets
e i will need besides tuning?
Old Dec 30, 2004 | 07:00 PM
MooreBoost's Avatar
Default Re: What else do i need? (00situner)
You do not need the inline pump or FMU.
You do need-
Walbro intank pump
Vacuum line
Boost controller
Bolts for Mani-->Turbo, DP-->Turbo, DT-->WG
Hondata chipped ECU
Turbo Manifold
The weldless bungs have leaked on occasion, I would just have it welded for a few bucks.
Modified by tegunderpressure at 4:35 AM 12/31/2004
Old Dec 30, 2004 | 07:02 PM
boosted eg's Avatar
sounds like your good to go
Old Dec 30, 2004 | 07:30 PM
B18 CYA's Avatar
wheres the turbo manifold ??
Old Dec 30, 2004 | 08:08 PM
Trac226's Avatar
Default Re: (B18 CYA)
Might want to pick up a set of colder spark plugs, intake filter, catchcan, boost gauge, and wideband if it's within your budget.
Old Jan 2, 2005 | 07:26 AM
00situner's Avatar
Default Re: (Trac226)
I have a Boost gauge and it comes with a tubular turbo manifold i forgot to list that and why is a intake fuel pump better than a inline? and what size injectors do you recommend for about 10 psi?
h22PreludeSi
Apr 21, 2005 06:29 PM
alexb16hb
Dec 23, 2004 07:06 PM
greencivichatch
Dec 6, 2004 04:00 PM
mstyper
Feb 12, 2004 05:23 PM
pub
Dec 2, 2002 07:13 PM
