Lensos, tappered or flat face lug nuts???
cant find a real answer on this in the "search section" so i figured since most of us run these in the FI section i would ask here
are lenso 13x7 inch drag wheels flat or taper faced lug nuts, i run OEM nuts on them and they come loose after each pass.
so help me out
so help me out
Re: Lensos, tappered or flat face lug nuts??? (mrbsponge)
i ran acorn lug nuts if that is what you would call them the same ones I run on my gram lights. Not the flat ones like I have to use on my bogart wheels.
Hope that helps
Hope that helps
I have run two type of tapered lugnuts, oem style and some tuner lug Gorillas and both haven't had any trouble with. The Lensos have a tapered base so you need to run those to center the wheel. Other than that I would try some new nuts
