How Is This Looking?
Old Dec 29, 2004 | 11:33 AM
91DroppedHatch's Avatar
Default How Is This Looking?
This is my entire set-up, I put one up a while back but that was just a lil at first, now I just need to know if anyone could look over this and tell me how much pounds of boost I can have with this setup. I wanna push around 400hp+ but I just need to know if the setup I have will be able to handle it. This whole setup is going into an 88-91 crx/hatch, havent decided which yet.
B20 Block
B18A Intake Manifold
Cold Air Intake
B18A Transmission
P75 LS ECU
“B” Series Engine Mounts/Linkage
Integra Axels
Spark Plugs
LS OBD-1 Distributor
4 Wire O2 sensors
Spark Plug Wires
Hondata w/boost option
Turbo Crower Cams
Cam Gears
Aluminum Flywheel
Stage 3 Clutch
Resleeve Block
8:1 Pistons
Eagle Rods
Skunk 2 Valves
Skunk 2 Springs
Skunk 2 Retainers
ARP Head Studs-
Turbo Cams Crower Cams
Blitz Turbo Timer
Apexi AVC-R Boost Controller
Precision SC32 Turbo
Intercooler Kit
Tial 40mm Wastegate
Full Race Turbo Manifold
3” Down pipe
Blow off Valve
AEM Fuel Rail
RC 750cc fuel injectors
Walbro Fuel Pump 255lph Kit
Custom 3" Cat-Back
Old Dec 29, 2004 | 11:36 AM
Makdaddynuge's Avatar
Default Re: How Is This Looking? (91DroppedHatch)
It all sounds good. You won't use a cold air intake though with a turbo kit. Compression is really low too. I would go with something like 9:1. But you will be able to meet your goal.
Old Dec 29, 2004 | 11:38 AM
Default Re: How Is This Looking? (Makdaddynuge)
Alrite thanks for looking over it, I also wanted to add LSD in the transmission but I heard that it snaps your axles easily or it robs horsepower or sumthin like that.
Old Dec 29, 2004 | 11:41 AM
LSVtechnologytur...'s Avatar
you could use the cold air intake as part of the intercooler piping
Old Dec 29, 2004 | 11:48 AM
StolenTeg's Avatar
Default Re: How Is This Looking? (vtec'n)
Wow, i dont know why but 8:1 compression is very low for a boosted honda. you would need a fair amount of boost to get your need, and the sc32 would get you there but im guesing you need to run very high boost.
Old Dec 29, 2004 | 11:49 AM
O ya imma have to make a custom intercooler piping rite
Old Dec 29, 2004 | 12:01 PM
You are gonna want LSD. Go with the quiafe. Without it, your traction will suck. And the sc32 is kinda small, it will get you there but it will take lots of boost. Go with a little bigger turbo.
Old Dec 29, 2004 | 12:20 PM
Default Re: (Makdaddynuge)
should I go with the SC52 or the SC60?
Old Dec 29, 2004 | 12:26 PM
i personally like the sc61, people make good power with them.
slick1851
Jul 24, 2010 10:30 AM
90turbosi
Feb 6, 2008 06:40 PM
vtecguy01
Jan 17, 2006 02:59 PM
91DroppedHatch
Nov 7, 2004 03:33 PM
B18 CYA
May 22, 2004 11:22 AM
