b18b 25psi safe?????????
Old Jan 8, 2005 | 02:44 PM
9900RPM's Avatar
Default b18b 25psi safe?????????
my buddy wants to know if
b18b
block sleeved,stock rods, je pistons 9.1 comp..
headgasket
skunk 2 valvetrain kit
with a t3 t4 turbo,ect.............
afc 2 , walbro 255 pump, fmu, and 550 venom injectors
will it hold 25 psi nice or what????????????????
Modified by 9900RPM at 3:57 PM 1/8/2005
Old Jan 8, 2005 | 02:46 PM
smoovy's Avatar
Default Re: b18b 25psi safe????????? (9900RPM)
I would say yes along with some good tuning and injectors. what size injectors, fuel pump and engine management besides the AFC will he be using?
Old Jan 8, 2005 | 02:53 PM
DENCIO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9900RPM &raquo;</TD></TR><TR><TD CLASS="quote">stock rods???</TD></TR></TABLE>
why stock rods?
Old Jan 8, 2005 | 03:08 PM
Chillin94hatch's Avatar
Default Re: b18b 25psi safe????????? (DENCIO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DENCIO &raquo;</TD></TR><TR><TD CLASS="quote">
why stock rods?</TD></TR></TABLE>
Old Jan 8, 2005 | 04:14 PM
TURBODC4TEG's Avatar
Default Re: b18b 25psi safe????????? (Chillin94hatch)
good questiON:?
Old Jan 8, 2005 | 06:10 PM
Junglesnake's Avatar
[QUOTE=9900RPM]my buddy wants to know if
b18b
headgasket
QUOTE]
No, @ 25 PSI on that turbo you will be pushing over 400 wheel HP. You will throw rods thru your block onto the ground. It could possibly stand a run or 2 if you were at least using Hondata or something along those lines, but with the AFC hack and that kind of power.....boom.
Old Jan 8, 2005 | 06:19 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9900RPM &raquo;</TD></TR><TR><TD CLASS="quote">my buddy wants to know if
b18b
headgasket
why when a decent set of eagle rods can be had for so cheap these days.....
Old Jan 8, 2005 | 06:23 PM
11psiTurboSI's Avatar
Default Re: b18b 25psi safe????????? (non-VTEC)
550cc injecotors are too small, no fmu, no afc... get some eagle rods, standalone (also a 3bar map sensor), and bigger injectors and you should be good to go!
Old Jan 8, 2005 | 06:44 PM
Evanmb44's Avatar
definately need rods...eagle all the way on that one
ems!!!! dont ignore one of the most important parts of making that thing run
Old Jan 8, 2005 | 06:53 PM
Ls1 FD3s's Avatar
Default Re: b18b 25psi safe????????? (Evanmb44)
25psi with stock LS rods only works perfect at 9900RPM's like your screen name states. Make sure to keep the stock LS rod bolts too.
Old Jan 8, 2005 | 06:55 PM
pimpintyperintegra's Avatar
for 25 psi, you need rods, big injectors...like 1000cc maybe 880cc, and hondata...you most definitely can't run that boost without some EMS. also you need a bad *** clutch to handle the power.
what turbo are you using anyway...needs to be pretty big to be efficient at 25 psi...like SC-61 or something.
good luck...if you get the above mentioned stuff and get it tuned properly, it should be pretty bad ***
Old Jan 8, 2005 | 06:59 PM
NVturbo's Avatar
O.G. triple O.G.
Yeah...you could run it ...but not for too long. I know some guys in here use the AFC hack but I suggest getting a REAL engine management system such as Hondata, AEM EMS, etc. Stock rods...come on! You can find good deals on some decent rods (EAGLES) for under $300 in the "Sponsor:Forced Induction" forum. Good luck.
xsi-t
Aug 21, 2005 08:31 AM
tegturbo
Jun 2, 2005 03:47 AM
jdm.ej
Apr 7, 2005 06:55 AM
brasilstreet
Aug 16, 2004 04:41 PM
dmotoguy
Feb 5, 2003 08:05 PM
