How much boost
Old Jan 10, 2005 | 07:55 AM
duiwrx's Avatar
Default How much boost
I want to turbo my "stock" b18b block. How much boost can the block safely take
Old Jan 10, 2005 | 07:59 AM
TheShodan's Avatar
Moderator
Default Re: How much boost (duiwrx)
It's not the just the block you must look at, it's the CFM of the turbo you're going to choose. If it is a hybrid turbocharger, about 7-14psi on various CFM turbos.
PM me if you need to understand the the right turbo for your application
Old Jan 10, 2005 | 08:10 AM
B18 CYA's Avatar
you should focus more on the amount of hp as your goal and not the amount of boost. 7 psi can give you 200 horsepower or it can give 300 hp depending on the size of your turbo, downpipe, etc. People have been boosted on stock blocks of even up to 350 whp. If I were you, 300 would be good with a conservative tune.
Old Jan 11, 2005 | 11:57 AM
duiwrx's Avatar
thankx, I just got rid of my WRX and once you go turbo it's hard to go back
Prudz_lude
Jan 21, 2013 08:00 AM
Slick o9
Jan 21, 2008 10:45 PM
97RSTEG
Jul 14, 2006 09:45 AM
