need help on choosing pistons and rods and sleeving company
i need help on what pistons an rods to get and possibly a re-sleeve job. I have a b18b motor and wnat to make around 350 hp. I want to go with arias pistons and eagle rods. How do i figure out how big of bore size to get for the pistons? And what is the biggest bore size a stock sleeve can handle? Please help so i can figure out if i need to resleeve or just use stock sleeves with the new piston and rod setup. I would most likely get a block gaurd if i dont resleeve..thanks
Re: need help on choosing pistons and rods and sleeving company (tspkenneth)
You can send it to us here in California to re-sleeve or to our new shop In Indiana @888-877-8484
81.5mm max on a stock ls block and 9-1 on the pistons.
Sleeved block you can start at 83mm
Re: (tspkenneth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">earl can fix u up with cp pistons, pauter rods, and benson sleeves, and great customer service</TD></TR></TABLE>
....couldnt have said it better myself. As for c/r i'd go with 9.5:1
JDM turbo DC
11-09-2005 12:55 PM
