Preparing engine for boost
Old Jan 9, 2005 | 10:22 AM
WoodlockAsHell's Avatar
Default Preparing engine for boost
What are some basic things to do to your engine to prepare it for boost?
Old Jan 9, 2005 | 10:26 AM
Andre's Avatar
Default Re: Preparing engine for boost (Woodlockashell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Woodlockashell &raquo;</TD></TR><TR><TD CLASS="quote">What are some basic things to do to your engine to prepare it for boost?</TD></TR></TABLE>
All stock blocks can take some boost. You have to tell which engine you've got and what your hp goals are.
Old Jan 9, 2005 | 10:28 AM
Default Re: Preparing engine for boost (Andre)
my engine is a b18A and im looking for around 250 horses
Old Jan 9, 2005 | 10:37 AM
Rod.'s Avatar
check the compression
Old Jan 9, 2005 | 10:41 AM
Sohc Driver's Avatar
250whp is easily achievable with a b18a. Here are a few things I would do prior to boosting:
-Check Compression in all cylinders(make sure they are all consistent and normal).
-Replace distributor cap, rotor, plug wires, & run NGK Bkr7e spark plugs.
-Run Mobil 1 synthetic motor oil if you are not already.
-Run oem honda oil filters if you are not already.
Thats what I did atleast. I hope this helps.
Khoi
Old Jan 9, 2005 | 10:53 AM
m R g S r's Avatar
Default Re: Preparing engine for boost (Sohc Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">-Run oem honda oil filters if you are not already.
Khoi</TD></TR></TABLE>
I've used fram filters since I got my car, no problems with em at all. . .
Old Jan 9, 2005 | 10:55 AM
Default Re: Preparing engine for boost (m R g S r)
what kind of head gasket should i get? I'm also in the process of looking for ARP head studs on ebay.
Old Jan 9, 2005 | 10:56 AM
EVIL Hx Coupe's Avatar
A few more..
Replace (if they havent been replaced recently)
- Oil Pump
- Water Pump
- Timing Belt
Make sure radiator is working perfectly.
Old Jan 9, 2005 | 11:07 AM
G
sh!t happens.
Default Re: Preparing engine for boost (EVIL Hx Coupe)
Just put the turbo on it.. hahaa I run 20w-50 castrol oil. and i would put a timing belt and water pump on it and put some plugs in it. check the Compression boost it and get it tuned, you'll be happy
Old Jan 9, 2005 | 11:10 AM
Default Re: Preparing engine for boost (G"UNIT)
lol sounds good
Old Jan 9, 2005 | 11:16 AM
should i keep the stock head gasket or get an aftermarket one?
Old Jan 9, 2005 | 11:38 AM
rothjpkb's Avatar
geting 250 out of a b16 is not to hard all you need is to pick a good kit
and make shure you have good fuel and timing and one thing for you to take
in to mind is a motor with higher compresion will make more power with less
boost so lets think you have 160hp now 90hp more easy and if your talking
250whp then all you'd need is about 120bhp more still not a problem with a
good boost contoler and remember to get a turbo timer it will save you life
Old Jan 9, 2005 | 11:54 AM
Default Re: Preparing engine for boost (rothjpkb)
its a B18A
Old Jan 9, 2005 | 06:25 PM
bump
Old Jan 9, 2005 | 08:25 PM
Benjithx's Avatar
if you are looking to spend money on something. Pistons and hondata will really help your reliabilty.
paniaguae640
12
Feb 21, 2008 08:05 AM
Satoonxtreme
Mar 9, 2007 04:43 AM
Wayne_Curr
Oct 21, 2005 03:41 AM
CB5F22A1
Oct 9, 2005 01:46 PM
ras
May 3, 2005 09:14 AM
