Wastegate banjo fittings?
Does anyone know where to find replacement banjo fittings for a TiAL wastegate? I bought one used and it came with some ghetto connectors.
Re: Wastegate banjo fittings? (turboteg2nv)
throw that **** in the garbage. I pulled the housing off, and re-tapped the holes to 1/8"npt, then you will have a lot of freedom in deciding what fittings you want to use.
It's easy and only takes a few minutes. PS, make sure you don't try to tap the holes with the gate assembled, you don't want metal shavings inside, they will damage the diaphragm.
Re: Wastegate banjo fittings? (ForceFedDetroit)
Cool, thanks for the idea. Maybe that's why mine came with some different connectors; i'll have to check the pitch and find a new fitting.
rioninja
08-30-2005 09:40 PM
