Clutch/Tranny Noise on my turbo Si?
Hey guys, im new to the site. I have a question, lately, whenever ive been starting off in 1st gear from a stop and ease the clutch out, ive noticed a faint squeak for the duration of the time im letting out the clutch (about two seconds), and it only happens in 1st gear from a stop. Now i dont know if it is because of my clutch (clutchnet stage 2 6 puck) that i havent even noticed yet until now, or if its something from the tranny. Any help or advice would be appreciated.
Re: Clutch/Tranny Noise on my turbo Si? (B00STED Si)
does it do it if your not going into gear..just sitting there pushing the pedal?
sounds like some sort of clutch chatter...maybe you got some oil on your clutch disc or something....
dont worry about it, not like its worth it to take it apart
if something goes bad just replace it
Re: (SoFa king fast)
sorry i dont think i described it too well....
the clutch pedal is pushed in, it is in 1st gear and i am at a dead stop. I slowly let the clutch out to start moving and you can hear a faint sqeaking sound from under the hood (not the pedal itself) the duration i let the clutch pedal out. The clutch is fairly new so i dont think its because the clutch has gone bad... im not sure tho.
Re: (B00STED Si)
did you change out the throw out bearing when you did the clutch install? i remember one of my friends car squeeked like yours and it turned out to be the throw out bearing being bent or something.
Re: (xrunner86x)
yeah i just talked to the guys up at the shop i work at and they said its a bearing, its just gonna squeak but it wont cause any problems. thanks guys.
hitvtecgetloud09
08-06-2005 08:55 PM
onetrueshyguy
21
04-29-2003 08:55 AM
