Base distributor timing with hondata
Old Jan 8, 2005 | 01:16 PM
vtec.dc2's Avatar
Default Base distributor timing with hondata
i need to do maintainance on my car, i'm running hondata s200, but what should distributor timing be? is it supposed to be the same for everyone (16 degrees) or it depends on the tuner.
Old Jan 8, 2005 | 01:37 PM
*Boostwerks*'s Avatar
Depends on the engine...but for most it is 16.
Old Jan 8, 2005 | 01:40 PM
vtec.dc2's Avatar
Default Re: (Bryson)
its itr but rebuild with 10:1 compression.. i'm making around 260whp
Old Jan 8, 2005 | 01:42 PM
Someone on here just asked this same question.
Always keep the base distributor timing to stock.
Tune the ignition map with the hondata.
Old Jan 8, 2005 | 01:46 PM
vtec.dc2's Avatar
my car has already been tuned, i can't get a hold of the tuner because he's not diong that stuff anymore. so i'm just left guessing.
if i set it to 16, and for some reason it was tuned with 18, will that lead to trouble?
Old Jan 8, 2005 | 01:49 PM
No...but the car will have a little less power is all.
2 degrees will be subtracted from all points in the ignition maps in your case.
Old Jan 8, 2005 | 01:52 PM
vtec.dc2's Avatar
so only less power, but no damage/detonation?
i'm guessing it would be worse if i set it to 18 and it was tuned to 16? right?
Old Jan 9, 2005 | 10:29 PM
turtle-eg's Avatar
Default Re: (vtec.dc2)
You can always find someone who tunes hondata to read your chip and tell you what the base timing was set to.
Old Jan 9, 2005 | 10:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (turtle-eg)
if you find out your base timing , thats what you should set the dizzy.
Old Jan 10, 2005 | 10:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">so only less power, but no damage/detonation?
i'm guessing it would be worse if i set it to 18 and it was tuned to 16? right?</TD></TR></TABLE>
Correct
Old Jan 10, 2005 | 10:32 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">You can always find someone who tunes hondata to read your chip and tell you what the base timing was set to.</TD></TR></TABLE>
good deal! thanks for everyones help
JDMlyfestyle
23
May 19, 2008 05:52 PM
Twistedframe
Feb 21, 2007 01:22 PM
done
Apr 8, 2005 07:13 AM
hybridsol
Aug 13, 2002 01:12 AM
