What's Your Base Timing???
Old Jan 7, 2005 | 07:21 AM
Dunc's Avatar
BCICAN
Default What's Your Base Timing???
Just a question for those who have a B16/18 Turbo.....what do you have your base timing at, and also what is your timing under full throttle?? I'd just want to try and figure out what is an established "safe" range for timing on a turbo car.
Old Jan 7, 2005 | 07:31 AM
SuperTeg95's Avatar
Default Re: What's Your Base Timing??? (Dunc)
20deg. at distributor
Old Jan 7, 2005 | 08:01 AM
m R g S r's Avatar
Default Re: What's Your Base Timing??? (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">20deg. at distributor</TD></TR></TABLE>
You sure that's not total timing? Seems high. . .
Old Jan 7, 2005 | 09:45 AM
Adriano's Avatar
Default Re: What's Your Base Timing??? (m R g S r)
16 at distributer
Adriano
Old Jan 7, 2005 | 11:21 AM
*Boostwerks*'s Avatar
Default Re: What's Your Base Timing??? (brryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brryder &raquo;</TD></TR><TR><TD CLASS="quote">16 at distributer
Adriano</TD></TR></TABLE>
Same.
Stock
Its always best to set the base distributor timing to stock, and tune the ignition map.
If your engine is low compression and/or bigger displacement you can add a little timing to the whole vaccum part of the map to increase off boost power and to get a better transition into boost.
Old Jan 7, 2005 | 12:59 PM
Dunc's Avatar
BCICAN
Yea I am at 16 degrees at the distributor......I am tuning with Hondata so you say I should just tune the boost section in the program and not the base timing?
Old Jan 7, 2005 | 01:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Yea I am at 16 degrees at the distributor......I am tuning with Hondata so you say I should just tune the boost section in the program and not the base timing?</TD></TR></TABLE>
Bingo.
Old Jan 7, 2005 | 01:09 PM
Dunc's Avatar
BCICAN
Default Re: What's Your Base Timing??? (Bryson)
Are you familiar with Hondata?? If so, on the ignition maps how do you determine your actual timing? Is the the program value minus or plus the base timing? Or is the program value the actual timing?
type-GGSR
Dec 26, 2007 09:52 AM
allnaturalb16
21
Aug 14, 2007 08:57 PM
downeyballz
Jun 11, 2007 06:38 PM
93civicExSI
11
Jul 8, 2006 04:03 PM
Daniel
Aug 22, 2003 07:05 PM
