oil capacity
Old Jan 10, 2005 | 05:55 PM
integratuner94's Avatar
Default oil capacity
I've asked this before and never got a solid answer.
After turbocharging an Integra, in my case an LS. Do you guys put more than the 4 qts. of oil in at an oil change or just stick with 4. I was told to put some more oil in...like 4 and a half qts. because you have oil lines and a turbo which will take more oil than just the motor the way it was from the factory?
Old Jan 10, 2005 | 05:57 PM
CivicEJ1's Avatar
Default Re: oil capacity (integratuner94)
Just add more oil after driving around the block so your at the second dot...
EG_Civic_Si
Feb 6, 2011 04:05 AM
CM-R
May 28, 2002 07:49 AM
