DOHC ZC turbo setup?
Old Jan 6, 2005 | 09:15 PM
MugenFlaredCRX's Avatar
Default DOHC ZC turbo setup?
I posted before about what I could use for my fuel management on my crx. i'm planning on running 10psi or less. i have a 255lph pump and pressure regulator. i was looking at the greddy e-manage unit, but i dont know exactly what else i need to make this work. any help would be great. thanks
josh
Old Jan 6, 2005 | 10:04 PM
second edition's Avatar
Default Re: DOHC ZC turbo setup? (MugenFlaredCRX)
ive got a grey plug zc with a greddy kit . the e manage blows in my opinion. i ran it all last summer, i was super rich and kinda bogging before warm up. im switching to hondata in the spring.
Old Jan 6, 2005 | 10:34 PM
drift2004's Avatar
Default Re: DOHC ZC turbo setup? (second edition)
why are you using heat wrap in your intercooler pipes? you want more heat going in your engine or what?
Old Jan 6, 2005 | 10:36 PM
Timmay's Avatar
Default Re: DOHC ZC turbo setup? (drift2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">why are you using heat wrap in your intercooler pipes? you want more heat going in your engine or what?</TD></TR></TABLE>
he probably has a FMIC so he wants to keep heat off the pipe
Old Jan 6, 2005 | 10:48 PM
Default Re: DOHC ZC turbo setup? (Timmay)
no front mount here.i got the wrap for free so i threw it on.The idea behind it was to reflect/keep heat from the engine bay from geting to the pipes,thus heating them. i may be wrong....intercooler this spring though
Old Jan 7, 2005 | 01:49 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenFlaredCRX &raquo;</TD></TR><TR><TD CLASS="quote">I posted before about what I could use for my fuel management on my crx. i'm planning on running 10psi or less. i have a 255lph pump and pressure regulator. i was looking at the greddy e-manage unit, but i dont know exactly what else i need to make this work. any help would be great. thanks
josh</TD></TR></TABLE>
I highly recommend against the e-manage. Id look into turboedit (its obd0 and free) or converting to obd1 and get a Neptune (which i run) or hondata. I can stress enough how important it is for a good fuel system to keep your turbo honda alive.
I just got my dohc ZC dyno tuned with the Neptune. 330whp on pump gas!
https://honda-tech.com/zerothread?id=1106644
liam
El pimp chulo
Aug 29, 2006 04:51 PM
MugenFlaredCRX
Jan 13, 2005 09:24 AM
flyingduck04
Oct 20, 2004 03:39 PM
Jaydo
10
Mar 16, 2004 08:43 PM
noname11
Apr 13, 2003 04:43 PM
