6 to 8 psi turbo setup correct or missing something help please ? b16a1
Old Jan 8, 2005 | 01:53 AM
marino1982's Avatar
Default 6 to 8 psi turbo setup correct or missing something help please ? b16a1
hello guys,
i have the following and want to install it on my crx
390cc dsm injectors
t3 turbo
homemade manifold
i want to go with fmu or vafc or both what do you recommend i know hondata is better but i don't want to go above 6/8 psi so i think i should be fine
also blow off valve and wastegate
is there anything else i need or what should be recommended except an intercooler ??
Old Jan 8, 2005 | 02:29 AM
W O T's Avatar
Default Re: 6 to 8 psi turbo setup correct or missing something help please ? b16a1 (marino1982)
A downpipe to connect your turbo to your exhaust
Oil feed/return lines (to feed turbo oil and return it back to oil pan lol)
Atleast a boost gauge
change out plugs or atleast gap your current @ 28-30
Youll be fine on low boost with an FMU or the hack
Old Jan 8, 2005 | 09:45 AM
11psiTurboSI's Avatar
Default Re: 6 to 8 psi turbo setup correct or missing something help please ? b16a1 (W O T)
I'd use both fmu and v-afc if your going to be using the 390cc dsm injectors
95dc2teg
May 24, 2006 08:18 PM
riddickone
Nov 23, 2003 06:38 PM
4doorsi
May 31, 2003 07:41 PM
Xscream
Feb 19, 2003 09:35 PM
supersonic-rs
Jul 25, 2002 09:35 AM
