WHAT WASTEGATES FOR A INLINEPRO T4 MANI?
what wastegates will fit on this? ive asked around and some people said that a tial will fit on it fine.. but then other people have said that only the turbonetics 40mm racegate will fit.. i looked on the inline pro site and they sell the turbo smart 38mm wastegate with their t4 kit.. will a tial wastegate fit on the manifold? or do i need to buy a flange?
will i be able to keep a/c or no? the inline pro website says that the manifold is a/c compatible.. but then some people who have it said that u lose a/c..
Re: WHAT WASTEGATES FOR A INLINEPRO T4 MANI? (jiggy)
Racegate is a bigger flange than the Tial, it won't fit. You can make an adaptor, a racegate flange and a 90deg. elbow with whatever flange you want to run on the other side. Here's one I did for Arturbo's car, 40mm Tial.
what other wastegate options do i have besides the racegate?.. i can run the turbo smart wastegate correct?.. what others?
The turbosmart wastegate is the only wastegate that will fit without using an elbow. Besides, the Turbosmart Ultragate flows more than any other 2 Bolt wastegate, and already comes race gas ready. Plus the Ultragate comes with all 7,10,14,17 psi spring combination in the box.
Re: WHAT WASTEGATES FOR A INLINEPRO T4 MANI? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Racegate is a bigger flange than the Tial, it won't fit. You can make an adaptor, a racegate flange and a 90deg. elbow with whatever flange you want to run on the other side. Here's one I did for Arturbo's car, 40mm Tial.
what is that big box under the IC piping? On the drivers side. . .
It's not a water to aire IC, is it?
Re: WHAT WASTEGATES FOR A INLINEPRO T4 MANI? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">
It's not a water to aire IC, is it?</TD></TR></TABLE>
Its a box leading the air from the removed headlight directly to the filter on the turbo...
Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart »</TD></TR><TR><TD CLASS="quote">The 38mm will fit with an elbow that converts the 4 bolt 40mm racegate to the standard 2 bolt 38mm.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls »</TD></TR><TR><TD CLASS="quote">The turbosmart wastegate is the only wastegate that will fit without using an elbow. Besides, the Turbosmart Ultragate flows more than any other 2 Bolt wastegate, and already comes race gas ready. Plus the Ultragate comes with all 7,10,14,17 psi spring combination in the box.</TD></TR></TABLE>
so uhm.. which turbosmart wastegate will bolt on the inline pro t4 manifold without any elbows or mods to the flanges?
Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls »</TD></TR><TR><TD CLASS="quote">the Turbosmart Ultragate will bolt directly up and require no adapter and it won't hit your hood</TD></TR></TABLE>
Not the T4 manifold. The T3 you can run the 38mm turbosmart and it will not hit your hood.
art
art
threes
Re: WHAT WASTEGATES FOR A INLINEPRO T4 MANI? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">Its a Momo Box.</TD></TR></TABLE>
lol
lol
Re: WHAT WASTEGATES FOR A INLINEPRO T4 MANI? (hondaguyef)
so.. what wastegate will fit on the inline pro ss t4 manifold without the use of an elbow that will still clear the hood?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiggy »</TD></TR><TR><TD CLASS="quote">so.. what wastegate will fit on the inline pro ss t4 manifold without the use of an elbow that will still clear the hood?</TD></TR></TABLE>
None.. You have to use an elbow.
As far as i know
1. the Racegate is 42mm not 40mm.
2. It fits on the Tial 2 bolt flange fine BUT.. oviously the Tial 35-38mm opening is smaller than the Racegate..( "As told by Cody from Love Fab").
I have a Racegate and as i was told i can put a Tial on the same flange just that the Hole on the flange will be of a diferent diameter.
Re: (fjt)
I cut a new flange out of some inconel on the water-jet and arranged it so everything cleared and tacked it... you have to make a flange and 90' combo.
Re: (Dublocivic)
there is no point in running a racegate (42 mm) on a tial flange (38mm) you are bottlenecking it and its gonna perform just like a 38......unless you bore the outlet of the manifold flange
