do i need datalogging?
Old Jan 7, 2005 | 12:02 PM
1.8's Avatar
1.8
Default do i need datalogging?
i've read on hondata.com what it is but i don't understand it. will i need datalogging? i won't be tuning myself. what is it exactly?
Old Jan 7, 2005 | 12:07 PM
Bulldogg83's Avatar
Default Re: do i need datalogging? (1.8)
I would say that if you are planning on racing the car on the track and you want to know what the car is doing, then yes I would get it. If you are not worried about it, and just want to go off of what your tuner tells you, then you won't need datalogging. Datalogging basically allows you to log air intake temps, timing, pounds of boost, redline, etc. which is beneficial to those on the track so they can make adjustments accordingly.
Old Jan 7, 2005 | 04:23 PM
1.8's Avatar
1.8
Default Re: do i need datalogging? (Bulldogg83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">I would say that if you are planning on racing the car on the track and you want to know what the car is doing, then yes I would get it. If you are not worried about it, and just want to go off of what your tuner tells you, then you won't need datalogging. Datalogging basically allows you to log air intake temps, timing, pounds of boost, redline, etc. which is beneficial to those on the track so they can make adjustments accordingly. </TD></TR></TABLE>
when you say "log", u mean in a computer?
Old Jan 7, 2005 | 04:37 PM
eddyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">
when you say "log", u mean in a computer?</TD></TR></TABLE>
Your are correct.
Old Jan 7, 2005 | 04:53 PM
1.8's Avatar
1.8
Default Re: do i need datalogging? (eddyboy)
basically, i'm better off with S100 since i'm not tuning anything by myself?
S100=tune by tuner
S200=tune by self or tuner
Old Jan 8, 2005 | 07:51 AM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">basically, i'm better off with S100 since i'm not tuning anything by myself?
S100=tune by tuner
?</TD></TR></TABLE>
yeah you would be fine with the s100.
Old Jan 8, 2005 | 12:39 PM
1.8's Avatar
1.8
thanks for the info.
Old Jan 8, 2005 | 12:49 PM
t3h_sl0w's Avatar
Logging is a neccesity no matter what.
Old Jan 8, 2005 | 12:58 PM
SOHC_MShue's Avatar
i know tuning my car without dataloging would suck!
Old Jan 8, 2005 | 01:12 PM
1.8's Avatar
1.8
Default Re: do i need datalogging? (SOHC_MShue)
u guys tune it yourself or have someone else tune?
Old Jan 8, 2005 | 01:16 PM
Battle Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">u guys tune it yourself or have someone else tune?</TD></TR></TABLE>
I have kpro...basically same thing. I use my datalogging quite a bit. Just to make sure everything is going well under boost while at the track.
I had mine tuned by the guys at VSV in Dallas, Texas
If I adjust anything, it's maybe ignition when/if I put higher octane at the track.
Old Jan 8, 2005 | 03:09 PM
tub_sephiroth's Avatar
Default Re: do i need datalogging? (02SilverSiHB)
Dataloggin is now standard with Hondata (well, with the s200)! Check out the link: http://www.hondata.com/
Old Jan 8, 2005 | 03:29 PM
Carlito Brigante's Avatar
Default Re: do i need datalogging? (tub_sephiroth)
Go with the S200. Eventually if you ever decide you want to tune your car you can use the s200 while s100 you will need to upgrade.
That link is correct, s200s now come standard with datalogging.
to hondata for hooking us all up with that.
kaiba
Jun 17, 2005 04:11 AM
B.
Jan 20, 2004 09:49 PM
JSR3STS
Audio / Security / Video
Nov 6, 2003 08:13 AM
redhatchb18
Honda Motorcycles
21
Oct 25, 2003 02:04 PM
civic-king
Sep 10, 2003 04:12 PM
