93 civic dx 160 000kms want turbo but is it worth it how to tell?
hey i have a 93 civic dx with 160 000km i bout it 6-7 mouths a go not sure how well its bin maintained and all that. Well i want turbo but not sure if the motor is in good shap for it or not. I Dont want to thow money Away fixing pure problems on a cheep dx motor.What should i do be 4 turboing the car????.
Re: 93 civic dx 160 000kms want turbo but is it worth it how to tell? (CivicEJ1)
Compression and leakdown test
And if you consume a lot of oil
160km's is only like 100k miles, not huge
I boosted my Crx with 279km's, mind you it lasted about 2 weeks but it was fun while it lasted
Canadian winters killed that car
yea i do consume alot of oil but no black coming from my exhust or any thing? ok so most shops can do a compression test and leak down test right. after that how do i determan if its ok to turbo or not? and are they any other things i should do?
thanks alot........
thanks alot........
Re: (ted)
its probably not a very good idea to turbo it, if its consuming a lotta oil. but do a comp. and leakdown test like everyone else suggested and post up the numbers here.
yea i put card bord under my car yester day and i checket it to day and theres a lil bit of oil that came from under the engine kinda in the midle but more to the passingers side. some one said its probly is a main seal lek. and every time a get my oil changes and i get a flush 2. My oil alway is black. Now im not sure if i should turbo it may be a should start looking for a d16 vtec engine and go from there.. ?
u think i should even bother geting a compressin test and all that. Even if i have a lil main seal lek and is useing more oil than it should. ? going to need a clutch installed to but thats with most turbo cars. But i dont no.. if i go for a si engine its probly easy to put in a clutch be for i swap it in and all that and will cost less money for labor? what do u thinks the smart way to go i realy want to trubo it bec its cheeper than buy a other engine but i dont want to wast my money >> please help me thanks...
Re: (ted)
well if ur thinkin of getting an Si (d16z6) engine, then ur not gonna be wasting anything by getting a turbo setup now, as you can swap tht over to the new setup.
you can wait till you get the swap and do it once and do it right. or if ur a lil impatient (like me ) go ahead and throw a turbo on this motor and see wht she can do.
Re: (ted)
dont worry about fixing the leaks man, compresison test it (takes 10 min and you can buy the tester for $24.99 at canadian tire, very easy to do)
Just when you turbo the car, make sure you have a spare engine or access to one asap so your car wont be down for long
Just beat the **** out of your dx until it takes a ****, swap in the new motor and transfer over the turbo **** to the Z6 engine
Id look into buying a D16a6 though, you can grab them with trannies and axles @ Speedpro on Spedina road for $100
honda_civic1993
10-12-2011 04:09 AM
HondaEF8R
11-25-2007 06:58 PM
