To boost or not to boost
Old Jan 10, 2005 | 03:22 PM
nucksDA32's Avatar
Default To boost or not to boost
That is the question. I have my B18a in myDA, getting a B16 later on about April to boost(Low 13's high 12's) but my question is, would it be worth it to boost the LS just for ***** and giggles? it's got over 200,000 miles on it, but I can get parts and pieces for a nice lil' 6lb daily driver easily. Should I, or just save up for the B16? I wanna be able to hang with my friends(85% are boosted) on the freeway right now, but it's hard But I'm not sure if it's really worth it to save money for the LS, when It won't be in there long. Decisions, decisions. Thanks in advance to any and all advice you are willing to give me.
Old Jan 10, 2005 | 03:24 PM
DefiantGSR's Avatar
Default Re: To boost or not to boost (nucksDA32)
build the LS block.
Old Jan 10, 2005 | 03:30 PM
nucksDA32's Avatar
I would build the block, but I'm not really trying to spend hella money on this motor cause I'm getting a JDM B16 to play with. I just want a little bit of LS fun before hand. My buddy tells me that I could boost safely on 8lbs with just a stock bottom end. May just do that.
Old Jan 10, 2005 | 03:32 PM
DefiantGSR's Avatar
Default Re: (nucksDA32)
F*ck the b16 and build the block.
Old Jan 10, 2005 | 03:33 PM
MikeMAN's Avatar
sell the JDM b16, use the money to buy pistons and rods, piece together a turbo kit..enjoy 300whp+ daily driven reliable
mike
Old Jan 10, 2005 | 03:37 PM
Dsm634's Avatar
LOUD NOISES
Default Re: (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">sell the JDM b16, use the money to buy pistons and rods, piece together a turbo kit..enjoy 300whp+ daily driven reliable
mike</TD></TR></TABLE>
Mike IS the man.
Old Jan 10, 2005 | 03:43 PM
The Destroyer's Avatar
Default Re: (Dsm634)
Turbo LS.
Build it and make some sweet power.
Old Jan 10, 2005 | 03:46 PM
DefiantGSR's Avatar
Default Re: (Vtaaak y0)
later down the road, if you're itching for VTACK, you could always add a VTACK head.
Old Jan 10, 2005 | 04:21 PM
hondaguyef's Avatar
Default Re: (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">F*ck the b16 and build the block.</TD></TR></TABLE>
For sure . Check the sig. It was a stock b18b Longblock, 150K mi. and 9psi.(out of a little Ta3). Daily driven as well. Torque owns The Butt Dyno
Phil
Old Jan 10, 2005 | 04:27 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (hondaguyef)
Boost your motor now, then get another B18 block with the $ your going to spend on the B16 and send it out- new rods pistons sleeves ect... Hello easy 400whp...
Blaze
Old Jan 13, 2005 | 10:04 AM
nucksDA32's Avatar
Default Re: (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Boost your motor now, then get another B18 block with the $ your going to spend on the B16 and send it out- new rods pistons sleeves ect... Hello easy 400whp...
Blaze</TD></TR></TABLE>
Okay, so I decided to boost the LS now It's got over 200,000 miles on it. What all should be done to ensure it lasts me till I can build something else?? Gaskets are still gravy, no leaks, I have to do a leakdown and compression test, need new cam seal, gotta convert to OBD1 cause I'm gonna Uberdata it(thanks Tay), that's about all I know for now. I wanna be careful with this motor, it's been through alot and it's all I got for now. It's gotta last me till I can get a new B18 bottom end or a B16, whichever comes first.
Old Jan 13, 2005 | 01:49 PM
Na-Spirit's Avatar
unless your friend has a really good tune for you to have to convert to uberdata go ahead, but seeing your obdo, why not use turboedit and not have to convert? save you some money, i used xenocron's tune from homemadeturbo.com, 75 dollars he socketed my ecu for me and put his dyno tune on it....tuned at 13psi with 450's , well turboedit style tune sooo we'll see how long she lasts.
mindless4banger
Engine Machining & Assembly
Jan 25, 2016 12:24 PM
ITRBOY1433
Oct 10, 2008 03:54 PM
ITR.#1446
Jul 24, 2008 06:00 PM
lloydadvance
Jan 8, 2006 12:38 AM
drvfast
Nov 16, 2003 10:13 PM
