welding return oil fitting
Old Jan 7, 2005 | 12:45 PM
Hyaboosta's Avatar
Default welding return oil fitting
I have a 2002 ex and I was wondering. since my oil pan is aluminum can the bung be mig welded or does it have to be tig? thanks
Old Jan 7, 2005 | 02:49 PM
triple_s1x's Avatar
Default Re: welding return oil fitting (Hyaboosta)
Tig would make it easier, but if your mig setup for Al you should be good also. To mig al you need a different liner, gas, and wire.
Old Jan 7, 2005 | 03:53 PM
evosol's Avatar
Default Re: welding return oil fitting (triple_s1x)
i'm sure you're aware but just in case... the bung should also be aluminum.
Old Jan 14, 2005 | 10:24 AM
MrBui's Avatar
since its aluminum.... dril and tap it...no need to weld
Old Jan 14, 2005 | 10:35 AM
RyanEJ8's Avatar
Default Re: welding return oil fitting (MrBui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBui &raquo;</TD></TR><TR><TD CLASS="quote">since its aluminum.... dril and tap it...no need to weld</TD></TR></TABLE>
It's better to weld it though. It only cost me about $20 to have it done to my aluminum D16Y8 pan.
Old Jan 14, 2005 | 10:38 AM
adseguy's Avatar
Default Re: welding return oil fitting (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
It's better to weld it though.</TD></TR></TABLE>
slooogsr
Feb 12, 2007 04:23 PM
nuttybumpo
Welding / Fabrication
25
Oct 1, 2006 05:07 PM
skiwithcars
Jun 29, 2006 01:38 PM
Shakes
Nov 12, 2004 02:29 PM
Phoenix_ITR
Mar 1, 2004 06:18 PM
