Problems with GE vaccum manifold....
Old Jan 6, 2005 | 06:46 PM
B16CRXT's Avatar
Default Problems with GE vaccum manifold....
has anybody had any problems with it? A buddy of mine was trying to explain somethign to me...just wondering if this is true??:
you will fill those lines with fake information
"because it takes it a while to fill those lines up due to the restrictive inlet for information so it takes the lines a while to read correct... so then if he lets off the gas and releases the air out of the charge pipes the wastgate is still gonna see boost when he isnt and it wont read boost when he is boosted hell be at like 6 psi when the wastgate sees 2 psi so its stays shut..when really it needs to start opening so he hits 10 psi and the wastegate sees 6"
He seems to beleive the only way for it to be right is to find separate sources for all of your vaccum needs (boost gauge, WG, Boost controoler solenoid). Is this true?
Old Jan 6, 2005 | 06:54 PM
MooreBoost's Avatar
Default Re: Problems with GE vaccum manifold.... (B16CRXT)
Im pretty sure it's caused by tapping after the TB. Line length has an effect on response, but nothing that large. Regardless, lot's of people run them without issue.
Old Jan 6, 2005 | 07:35 PM
turbosi03's Avatar
Default Re: Problems with GE vaccum manifold.... (MooreBoost)
bump... I would like to know also because I'm about to buy one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure it's caused by tapping after the TB.</TD></TR></TABLE>
I thought you source dist block from IM?
Old Jan 6, 2005 | 07:38 PM
B16CRXT's Avatar
Default Re: Problems with GE vaccum manifold.... (turbosi03)
your main line to the vacc manifold is from the brake booster.
Old Jan 6, 2005 | 07:59 PM
Race Egr's Avatar
so is that where u want the vacuam manifold to run from?
Old Jan 7, 2005 | 03:58 AM
MooreBoost's Avatar
Default Re: Problems with GE vaccum manifold.... (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">so is that where u want the vacuam manifold to run from?</TD></TR></TABLE>
Yeah. But regardless, it's after the TB.
Old Jan 7, 2005 | 05:03 AM
B16CRXT's Avatar
where else would you do it?
Old Jan 7, 2005 | 05:07 AM
mike1114's Avatar
I've had a vacuum mani for over a year, no problems ever!! No boost spikes, no wastegate seeing boost when it shouldn't, nothing.
I think your buddy is smoking lawn clippings!!
Old Jan 7, 2005 | 05:31 AM
boosted-delslow's Avatar
Default Re: Problems with GE vaccum manifold.... (mike1114)
I have one in my car that is hooked up in line with the brake booster and it works great. Never had any problems with it.
Old Jan 7, 2005 | 06:25 AM
turbosi03's Avatar
Default Re: Problems with GE vaccum manifold.... (boosted-delslow)
golden eagle has a diagram (on their website) that shows their block sourced from the intake mani... then the dist block feeds the brake booster... is that not right??
Old Jan 7, 2005 | 06:55 AM
ladysman's Avatar
Old Jan 7, 2005 | 09:33 AM
RyanEJ8's Avatar
I ran mine from the the port on the intake manifold that used to be for the PCV. It's 3/8" just like the brake booster, only it's not sharing vacuum readings with the brakes.
Old Jan 7, 2005 | 09:37 AM
Boosted2K's Avatar
Default Re: Problems with GE vaccum manifold.... (RyanCivic2000)
Mine is run exactly like the pic above, I never had an issue with it
Old Jan 7, 2005 | 10:18 AM
turbosi03's Avatar
Default Re: Problems with GE vaccum manifold.... (Boosted2K)
ok, so it sounds like you just need a LARGER diameter vacuum source from the IM and you should be set.
clean setup ladysman
Old Jan 7, 2005 | 10:48 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">
clean setup ladysman </TD></TR></TABLE>
Thanks..............but it is all gone now.
And I never had an issue with it either in the 1 year it was on before it was removed.
Old Jan 7, 2005 | 10:51 AM
ATS*Mark's Avatar
OG triple OG
ive never had a problem with mine....
you can see how its hooked up here.
sanman000719
Sep 2, 2011 02:16 PM
pataww2001
Oct 14, 2006 09:28 AM
B18 rider
Aug 23, 2005 01:08 PM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
ATS*Mark
Dec 26, 2003 10:48 AM
