water temps , where are you guys sitting at?
OG triple OG
doing some datalogging and playing around with hondata a little bit i noticed my water temp was hovering righht at 180 degrees , never got above , sometimes droped to 178 or so. just wondering if this was high for a y8. any motor setup post your temps!
Re: water temps , where are you guys sitting at? (Hella_JDM)
Thats about right pretty much ideal temp. My A6 at idle would some time go as high as 215 before the fan kicked in, but would come down to around 180ish when driving.
OG triple OG
Re: water temps , where are you guys sitting at? (turbozxi)
my fans on all the time.....it doesnt really go above or below the 180 range....i just wasnt sure if it was a little high or not.
No its the ideal running temperature. Obviously when you first start the car its cooler right.
OG triple OG
lol , naw it seems to be at 180 before i start it too , wierd!!!
naw , im sayin that it never gets past 180 , never goes below 178 once it reaches operating temp.
Holds steady at ~176-180*F on the street with the fans kicked on all the time. Hits about 190-193*F on the track(road course).
Koyo radiator, FAL dual 12" fans, SR20DET. A big radiator is a must if you boost longer than 15 seconds or so.
