Looking forward to boost or supercharge questions
Old Jan 9, 2005 | 04:55 PM
hahaitzsteven's Avatar
Default Looking forward to boost or supercharge questions
I been racing it all motor and wanting to have more power without switchin out pistons and others...I got 12-1 compression sleeved 2.0L and wanting to boost or supercharger... But the question im asking is how much i can boost max on both and how much estimate power can i make?... My motor is fully built from head to bottom...
Old Jan 9, 2005 | 05:56 PM
beepy's Avatar
Default Re: Looking forward to boost or supercharge questions (hahaitzsteven)
Zero boost. With 12:1 compression you are already close to detonation. You cannot build an engine to maximize all motor power and then strap a turbo on it.
Old Jan 9, 2005 | 06:02 PM
IRev2NineK's Avatar
hmm. how much boost you can run on a 12:1 compression
that's easy, none. if you do want to boost, you're going to have to lower your compression (maybe down to 10 at the least). so that means there is no gettin around swapping pistons, rods, etc. since you have taken time and money to build a N/A car, i say stick with the N/A setup. saves time and money. but if you do have the time and money to rebuild your motor, then i say go right ahead and boost.
whatever you decide, i wish you best of luck
Old Jan 9, 2005 | 06:09 PM
2point2's Avatar
https://honda-tech.com/zerothread?id=1027496
P-ridge28
Feb 18, 2012 05:51 AM
SiTR
Jan 28, 2007 05:42 PM
SiTR
Jan 11, 2007 10:00 PM
deemack79
Feb 14, 2005 05:33 PM
