h22 turbo compression
Old Jan 6, 2005 | 02:57 PM
jdmlude01's Avatar
Default h22 turbo compression
Arias piston makes h22 turbo pistons with a compression of 8.4:1. Compression sounds a little low to me. I know with a lower compression most likely I will have more turbo lag but what is the advantage of getting this low of a compression?
Old Jan 6, 2005 | 03:23 PM
BB6-213's Avatar
The lower the comp., the more boost. I am planning on running 9.8:1 in my h22.
Old Jan 6, 2005 | 04:18 PM
s2kdre's Avatar
Default Re: (BB6-213)
i guess the sleeves are thin and weak in the h22s.
Old Jan 6, 2005 | 04:19 PM
flip1199's Avatar
Default Re: (jdmhonda)
more boost on pump gas. what are your goals? and the sleeves arent thin and weak...
Old Jan 6, 2005 | 05:58 PM
PrettyLude's Avatar
one more reason is a bigger window for error
Old Jan 7, 2005 | 02:41 PM
jdmlude01's Avatar
Default Re: (flip1199)
My goal is to be in the 300whp range. Yes this will be my daily driver and I want to be able to use pump gas.
Old Jan 7, 2005 | 03:38 PM
PrettyLude's Avatar
9 to 1 would be perfect
Old Jan 7, 2005 | 03:44 PM
flip1199's Avatar
Default Re: (jdmlude01)
well since your only shooting for 300whp you can safely go 10:1
BADxKARMAx
Oct 13, 2012 09:25 PM
icebergli
Jul 20, 2005 10:28 AM
icebergli
Jul 18, 2005 08:25 PM
Sartol
Sep 22, 2004 09:22 AM
veryslowaccord
Jun 17, 2003 05:51 AM
