precision intercooler what to clean it with?
Old Jan 10, 2005 | 11:14 PM
TURBODC4TEG's Avatar
Default precision intercooler what to clean it with?
my intercooler is starting to look a little brown and chalky
what should i clean it with
or what is good to clean cast with
thanks
Old Jan 11, 2005 | 01:06 AM
mrspeaker's Avatar
Default Re: precision intercooler what to clean it with? (TURBODC4TEG)
Steam cleaner..
or a pressure washer at low pressure so you dont bend the fins..
Old Jan 11, 2005 | 01:39 AM
Default Re: precision intercooler what to clean it with? (Mrspeaker)
i'm talking about the outter edges
the end tanks
Old Jan 11, 2005 | 02:26 AM
NightRiderS2K's Avatar
In-N-Out Burger
Polish?
Old Jan 11, 2005 | 06:28 AM
adseguy's Avatar
Default Re: precision intercooler what to clean it with? (NightRider-gsR)
What ever you do. DON't USE WATER! it wil get in teh intracooler and ***** your engine later with watre lock.
I say use anything you want. Personally i just go to the self-car wash and use the high pressure hose, then i go home get a flathead screw driver and get the bugs out without bending fins. I even straighten out some fins that got hit with rocks while I'm at it
Old Jan 11, 2005 | 06:43 AM
yellowturbo's Avatar
Some Castrol Super Clean mixed 1/2 with some clean water, and a brush to clean it. Work for my old Trust/Greddy IC that I have for like 4 years or so... it looks like a new one except for some fins loll
Old Jan 11, 2005 | 10:33 AM
Default Re: (yellowturbo)
thanks guys but its not polished its cast, like the compressor housing on the turbo, i tried polish turned it dark gray, any other suggestion, simple green and sand paper?
Old Jan 11, 2005 | 10:36 AM
Sprockets's Avatar
Default Re: (TURBODC4TEG)
Use wet/dry sandpaper, then Mothers.
Old Jan 11, 2005 | 10:40 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (B16A Grenade)
precisions intercoolers are aluminum correct? just use some diluted hydrophloric (i think, might be hydrochloric, need to check) acid./ we use that on our aluminum trailers all of the time. works like a charm
Old Jan 11, 2005 | 10:41 AM
Ri5e's Avatar
Here's what I did ...
Originally my intercooler end tanks were very grainy (cast). I used low grit sand paper then went to a higher grit. Finally, wet sanded it and polished it up with red rouge on a buffer wheel:
(I wish I had the before pictures)
Old Jan 11, 2005 | 10:48 AM
Default Re: precision intercooler what to clean it with? (TurboSmart)
sweet thanks man
i know i have tried to polish the center where the bars and fins are it didn't take to well to mothers polish
Old Jan 11, 2005 | 11:24 AM
sykotik sol's Avatar
or you can always do what i did...
Old Jan 11, 2005 | 11:26 AM
Tactic$'s Avatar
Default Re: precision intercooler what to clean it with? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">What ever you do. DON't USE WATER! it wil get in teh intracooler and ***** your engine later with watre lock. </TD></TR></TABLE>
lol... i remember that thread!
Old Jan 11, 2005 | 02:51 PM
Default Re: precision intercooler what to clean it with? (Tactic$)
i've used water to clean mine before whats wrong with that?
Old Jan 11, 2005 | 03:54 PM
up
Old Jan 11, 2005 | 04:14 PM
J-Brooks's Avatar
I work at acura and use some kind of acid from cougar detailing supplies. works great. I am sure there are similar chemicals that are easier to get.
Old Jan 11, 2005 | 06:48 PM
Sprockets's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG &raquo;</TD></TR><TR><TD CLASS="quote">i know i have tried to polish the center where the bars and fins are it didn't take to well to mothers polish</TD></TR></TABLE>
I wouldn't have done that. That **** gets in the crevices, and is a pain to get out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">precisions intercoolers are aluminum correct? just use some diluted hydrophloric (i think, might be hydrochloric, need to check) acid./ we use that on our aluminum trailers all of the time. works like a charm</TD></TR></TABLE>
Please find out if hydrochloric acid is safe to use on the fins. They're so delicate, and nothing I've used seems to work well. I used Castrol Super Clean, but it left a residue, and even water pressure from a garden hose bent the fins. Hydrochloric acid would dissolve the bugs trapped in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Brooks &raquo;</TD></TR><TR><TD CLASS="quote">I work at acura and use some kind of acid from cougar detailing supplies. works great. I am sure there are similar chemicals that are easier to get.</TD></TR></TABLE>
I think I know what you're talking about. Is it wheel cleaner?
For the inside of the intercooler, there's a parts store near me that sells gallon containers of CRC chlorinated brake cleaner, instead of the cans that run out of propellant and leave a little in the bottom. I just capped one end, poured it in, let it sit on end, turned it over, let it sit, then shook it and emptied it out. Just to be thorough, I poured some more CRC in to flush it out some more. Obviously, I had time to let it completely dry out. If you do this, make sure to use the chlorinated stuff, which is non-flammable. It would be interesting to use the flammable stuff, then start the car.
Old Jan 11, 2005 | 08:16 PM
KFMRC's Avatar
you can use aluminum wheel cleaner or go to a welding supply and get aluminum cleaner which is almost the same thing you can also get aluminum cleaner at most big truck shops
Old Jan 11, 2005 | 09:57 PM
J-Brooks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade &raquo;</TD></TR><TR><TD CLASS="quote">
In detail we mostly use it on wheels yes. Its almost a clear substance.
Old Jan 11, 2005 | 09:59 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (J-Brooks)
In detail we mostly use it on wheels yes. Its almost a clear substance.</TD></TR></TABLE>
muratic (sp?)acid. we use it on wheels
Old Jan 12, 2005 | 11:12 AM
thanks
Old Jan 12, 2005 | 11:56 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">What ever you do. DON't USE WATER! it wil get in teh intracooler and ***** your engine later with watre lock.</TD></TR></TABLE>
I hope you mean dont fill it up with water.. If you clean the outside of it, it isnt going to get inside the intercooler..
Old Jan 12, 2005 | 11:58 AM
tgreaves's Avatar
muratic (sp?)acid. we use it on wheels</TD></TR></TABLE>
hehehe.. I've used this before.. just pour it on and brake dust runs off.. Also if you have white lettering on the sidewalls of a car it will make then bright and shiny..
Old Jan 12, 2005 | 02:21 PM
adseguy's Avatar
Default Re: precision intercooler what to clean it with? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
I hope you mean dont fill it up with water.. If you clean the outside of it, it isnt going to get inside the intercooler..</TD></TR></TABLE>
Notice how I wrote it. I was kidding
Old Jan 12, 2005 | 02:41 PM
Madness's Avatar
Muriatic acid = hydrochloric acid.
Truckers have been using it for years as aluminum wash.
Just make sure you don't leave it on too long as it will actually
etch/eat the surface of the metal. Then flush with plenty of cool
running water.
And don't get it on paint. or let it sit on anything you want to keep nice,
including concrete.
